Old 08-08-2012, 02:50 PM   #1933
Don@Accelerated
Don@Accelerated's Avatar
Originally Posted by Warex View Post
I'm sure this has been addressed but are you guys only adding fuel through the port injectors? Has the DI system been addressed yet?
We have full control of both port and direct injection. Not using the direct injection is a mistake from our viewing angle.
Don@Accelerated is offline   Reply With Quote
Old 08-08-2012, 03:28 PM   #1934
serialk11r
Drives: '06 AM V8V Coupe
Originally Posted by Don@Accelerated View Post
Previously I had 4psi at 2800rpm. The dynojet 24" roller does not have the weighr resistance like the car. We are actually allowing the turbo to come on a bit smoother so that we do not have to much torque down low on the stock engine. All I would need to do is put a 10psi wastegate spring in it and it would come on much harder. I want to know what this will do reliably. We could always crank on it, but its not what we were after. I could post up a final run count, but i'm sure its around 170 Dyno pulls now since turbo.
Don
Oh is that right? Any plans on electronic wastegate control? If the 5psi wastegate is at work at low rpm, that seems like it would help to have slightly higher A/R turbine housing but fully closed wastegate. Something like that, to increase the turbine's efficiency a little, and have less exhaust bypassing via wastegate. Or I could just be misunderstanding and totally talking out of my ass.
Old 08-08-2012, 03:34 PM   #1935
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
They are already running the .86ar housing in a tial vband setup. Not going to get much freer flowing than that on this frame of turbo.
The torque coming on smooth has to help with knock resistance on the low-end, where knock seems to be more of an issue. I am interested in how quickly the boost could ramp up on this compression, but if concerns about the engine's strength arise I can see why it is toned down a bit.
But perhaps things will change when the rich guys get a hold of this engine and push it to the limit.
Coheed is offline   Reply With Quote
Old 08-08-2012, 03:35 PM   #1936
xcelir8brz
Drives: 2013 BRZ Limited
Amazing progression with this project.
Can't wait to see the final outcome on an Automatic!
xcelir8brz is offline   Reply With Quote
The Following User Says Thank You to xcelir8brz For This Useful Post:
blackfireball5 (08-09-2012)
Old 08-08-2012, 03:37 PM   #1937
serialk11r
Oops, did not notice that, thanks. Still, some kind of non-passive wastegate control would be cool As far as knock resistance goes, when you have boost I think that can actually make things a little easier because if you can get the cam overlap right then you get a much better scavenging effect, which will reduce temperatures. But getting the cam overlap just right is hard.
Old 08-08-2012, 03:42 PM   #1938
Coheed
Coheed's Avatar
Exactly. Its a balancing act between backpressure and overlap. I always built in a boost spike on my setups to keep the wg closed as long as possible, but I agree its not always the best option.
Old 08-08-2012, 03:48 PM   #1939
Synack
Boosted
Synack's Avatar
Drives: Sideways
You can e-tune with John. Get a decent base map, then datalog, send, get new flash, reflash, datalog, send, get new flash, etc, etc, etc same as your tuner, but John's basemap will make the process a LOT faster and safer, plus he clearly knows this system very well now.
Now if you went Pro EFI.... :P
I was very close to pulling the standalone trigger.... Decided against it though as I'm not trying to get big numbers or do anything crazy with my car. Just a nice elegant drift/show car that can also be a reliable DD with good gas mileage. It is my DD after all.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 08-08-2012, 03:54 PM   #1940
Coheed
Coheed's Avatar
This is the smart route anyway. A lot of factory computers have capabilities to do 90% of what a standalone can. And you keep the vehicle road-legal in the process.
Old 08-08-2012, 04:36 PM   #1941
knapper
knapper's Avatar
Drives: '13 Scion FR-S - Whiteout
Originally Posted by TouchMyHonda View Post
Anyone complaining about price has simply never turboed a not turbo car or built a car up really.
That is a bit of an uneducated blanket statement. I have owned/created several turboed vehicles throughout my driving life and not once have I spent over $2000 for parts, the labor I did on my own, and tune never more than $1000.
In my opinion, $8000-$10,000 to turbo this car with a basic kit ... is not only too rich for my blood, but only hitting the minority. And to state that having a reliable good quality turbo kit for $2000-$3000 is not possible, is just plain ignorant.
knapper is offline   Reply With Quote
Old 08-08-2012, 04:50 PM   #1942
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
... without a junkyard/custom setup.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 08-08-2012, 05:28 PM   #1943
bakerr6
Drives: 2013 raven black fr-s
my total kit for my stang, with the tuning option came out right around $3500. I know that's probably high for a car that is so mass-produced, but it ws completely custom, and ceramic coated. That also included the tune.
It is possible, if you have the will, skill and time
bakerr6 is offline   Reply With Quote
Old 08-08-2012, 05:36 PM   #1944
.Alex
Drives: Scion
You took the time and $$$ to R&D a turbo kit from the ground up?
It cost alot of money to do this kind of thing and companies have to recoup what they've spent along with making a profit.
I agree an $8k-$10k turbo kit would be too expensive, but charging $5-$6k seems very reasonable imo.
.Alex is offline   Reply With Quote
Old 08-08-2012, 05:41 PM   #1945
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
It's normal for a kit, but you can put together your own setup for less, but yes, you have to deal with fabrication, fitment, etc.
Part of what you are paying for is a sorted kit that requires no (or little) modification.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 08-08-2012, 06:09 PM   #1946
SnapOv3st3r
Drives: 400whp Scion tC
A good clue would be how much boost there is at highway cruising engine speeds. Now since their dyno run starts at ~2500rpm it's a little hard to tell, since the transient response of the turbo is an issue, but it looks like the turbo doesn't really "spool up" until you hit well over 3500rpm.
Any fuel economy loss at steady low load cruising conditions will be due to the turbine adding restriction to the exhaust, which doesn't seem like it's going to be a big deal. Most turbo engines "spool" well before this one does.
Under normal acceleration, engine efficiency will drop a little bit when you use boost, but again it appears there is very little boost below 3000rpm so probably not going to impact fuel economy much.
Best if they can tell you how much boost it builds in the lower engine speed ranges, and if they have any exhaust pressure readings (probably not going to be a significant increase).
You can drive to 6k rpms and still not spool a turbo. Exhaust gases drive the turbine, not rpms. There is VAC and there is Boost.
SnapOv3st3r is offline   Reply With Quote
accelerated performance, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
Accelerated Performance 2013 BRZ Intake Dyno Testing Video Don@Accelerated Engine, Exhaust, Transmission 109 05-17-2013 11:24 AM
Accelerated Performance 2013 BRZ Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 135 09-03-2012 11:24 PM
Accelerated Performance 2013 BRZ/FRS Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 24 07-07-2012 07:05 AM
Hello from Accelerated Performance! Don@Accelerated Announcements, Contests, Giveaways 5 07-04-2012 08:14 PM
