Old 08-06-2012, 11:06 PM   #1779
subatoy
subatoy's Avatar
Drives: subatoy
Originally Posted by serialk11r View Post
Super impressive, just wondering, what are the manifold temperatures looking like? psi doesn't tell you how much air is going in And you say the wastegate is set at 5 psi? How's that doing?
Also, I'm getting a little nervous as I think you guys have passed the stock transmission rated torque capacity :O Good luck.
what is the torque capacity on the manual?
subatoy is offline   Reply With Quote
Old 08-06-2012, 11:14 PM   #1780
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Originally Posted by Chewie4299 View Post
Another vendor on the forum that shall remain unnamed here did a whole slew of runs in 3rd thereby inflating their numbers next to all the competition.
John and Don - just to be clear I'm not accusing you of this. Most cars are nearest to 1:1 in 4th if I'm not mistaken. I would like to see 5th gear numbers but that may be asking a lot if you've been using 4th all along.
Sent from my Galaxy Nexus using Tapatalk 2
back to back dyno comparison on dynojet on 3rd vs 4th. Longer gears = more heat soak. Lesser powered cars do better on this 248c dyno because the pull isn't as long, so heat doesn't sink in. But slower cars have trouble spinning this roller to 110+mph, and the pulls take too long. But you can see the powerband is slightly affected, peak power IS NOT affected. And this is the story pull-after-pull. I did a 2nd gear pull and the vehicle lost power due to wheel spin though.
Don't worry about the gear, on a dynojet it isn't going to matter. Not peak power at least. You will spool the turbo quicker though in 5th. And the powerband will look more broad.
Coheed is offline   Reply With Quote
The Following User Says Thank You to Coheed For This Useful Post:
nix (08-06-2012)
Old 08-06-2012, 11:18 PM   #1781
Synack
Boosted
Synack's Avatar
Drives: Sideways
Well if you are looking for under the curve then we can't really measure everything exactly but peak doesn't seem affected. Thanks for sharing.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 08-06-2012, 11:24 PM   #1782
Synack
Boosted
Synack's Avatar
Drives: Sideways
So we are currently at ~272whp/215wtq on 'unconfirmed' 8 psi.
So with a bit more tuning and a free flowing exhaust I don't see any reason why this car can't hit 300whp. And all on an untouched stock internals. Can't wait to see how everything holds up and what numbers are grinded out of 8psi.
Old 08-06-2012, 11:25 PM   #1783
nix
nix's Avatar
Drives: AVO BRZ
You shoud start a new thread with this post and get it stickied!
nix is offline   Reply With Quote
The Following User Says Thank You to nix For This Useful Post:
Sportsguy83 (08-07-2012)
Old 08-06-2012, 11:31 PM   #1784
Coheed
Coheed's Avatar
Originally Posted by Spaceywilly View Post
HP = torque * RPM / 5252. You can't bump one without bumping the other. What you could do is focus on making a flat torque curve (better for the street) as opposed to a lot of high end power (better for track) but it looks like they've got a really nice flat curve already.
I'm sure he meant more torque with the same peak whp. If that is the case, a restriction would have to be present. Either that, or have a boost spike in the mid-range.
Old 08-06-2012, 11:37 PM   #1785
Coheed
Coheed's Avatar
like was mentioned earlier though, the eddy current dynos can be different because they don't measure acceleration of a fixed mass. But the longer the pull, the less peak power is produced... typically. Lots of variables between dynos. But on the Dynojet 248c, with added ballast to 1500whp+ capability, the results speak for themselves.
Old 08-06-2012, 11:41 PM   #1786
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
Originally Posted by Don@Accelerated View Post
So I guess theres no dyno on here of 281hp and 220+ft lbs
Glorious. You've made our 'sports car' a truly formidable sports car.
If the stock internals will hold up, I'm in.
Thanks again for being so transparent. My Accelerated Performance exhaust will be delivered tomorrow and then it's just a matter of time before the turbo joins it!
cobrabyte is offline   Reply With Quote
Old 08-06-2012, 11:50 PM   #1787
Coheed
Coheed's Avatar
This still on factory injectors?
Old 08-06-2012, 11:58 PM   #1788
Synack
Boosted
Synack's Avatar
Drives: Sideways
Ooooh I need to hear that exhaust. I'm going with the GReddy EVO3. Only because I asked what size the Accelerated Race exhaust was and not a single person answered.
Old 08-07-2012, 12:29 AM   #1789
serialk11r
Drives: '06 AM V8V Coupe
I think it's 300 Nm. Since they're seeing calculated 220 ft-lb on the dyno, they should be a tad bit over at the crank.
Old 08-07-2012, 12:35 AM   #1790
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
What would cause you to believe that? This is practically a new transmission. They took one they already had and redesigned 80% of it. We've yet to learn it's limits as far as I know.
Here's the article I read this in. I'm just running my mouth based off this...
http://kaizenfactor.wordpress.com/20...n-or-is-scion/
Chewie4299 is offline   Reply With Quote
Old 08-07-2012, 12:36 AM   #1791
Coheed
Coheed's Avatar
Rated torque capacity is just a guideline on what the OEMs can guarantee... You can usually push them to 150% capacity for a time on the track, or 300% for a weekend warrior that doesn't see a lot of abuse.
I took a transmission rated at 150tq and pushed 440tq through it for a few months before it grenaded. But it took to 350tq for years without issues. I'm sure 300wtq will do just fine for most. Keep a sprung clutch, and good gear oil. Should do just fine.
Old 08-07-2012, 01:45 AM   #1792
Coheed
Coheed's Avatar
Stock injectors? Also this is a .86 vband housing?
accelerated performance, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
Accelerated Performance 2013 BRZ Intake Dyno Testing Video Don@Accelerated Engine, Exhaust, Transmission 109 05-17-2013 11:24 AM
Accelerated Performance 2013 BRZ Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 135 09-03-2012 11:24 PM
Accelerated Performance 2013 BRZ/FRS Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 24 07-07-2012 07:05 AM
Hello from Accelerated Performance! Don@Accelerated Announcements, Contests, Giveaways 5 07-04-2012 08:14 PM
