Old 06-10-2026, 09:34 AM   #15
RongTurnRacing
RongTurnRacing's Avatar
Drives: 2013 Subaru BRZ Turbo
I have 5 cars. My 2015 twin has 30k miles on it. I've gone 6 years between oil changes and Blackstone says my oil is like new. Modern synthetic oil does not collect moisture, or break down with just time. Waste your money and time changing good oil if you want...
Honestly, I used to think the same thing. Unfortunately, it's not that simple. I have 6 cars. 3 are always in the garage when not in use. The other 3 are parked outside. Of those, two are driven regularly and one is parked because it's only used for RallyX. I've never had an issue with the 5 but the RallyX car had a ton of moisture in the oil every time I've changed it at the start of the season after letting it sit outside for 6 months. At first I thought I had a coolant issue but then realized that it was just attracted moisture.
Aside from that, how much are your cars worth to you? "Wasting money" is a questionable statement for such a low cost maintenance item that has a high cost if you have a failure due to that issue.
To each their own. It's the internet and opinions are like a-holes.
RongTurnRacing is offline   Reply With Quote
Old 06-10-2026, 10:15 AM   #16
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I trust what my oil analysis says.
Old 06-15-2026, 08:53 PM   #17
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
I have a 2004 WRX that sees about 1500 miles/year. My BRZ sees more now at about 4-5k/year.
I used to change it every 6 months, but I've been going about a year. Haven't noticed any difference. It's only 1500 total, but there's a decent amount of idling and cold starting for winter when it's used more when the BRZ gets put away in the garage for 5 months.
Personally, I'd do yearly. It's not that expensive. Get an oil analysis done. My main concern would be water or fuel depending on how it's driven. I do them on the BRZ, but not WRX due to the mileage it sees now.
cmiovino is offline   Reply With Quote
Old 06-16-2026, 12:02 PM   #18
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
I change oil and filter once a year, which is less than 3000 kl.
My garage queen only appears for occasional pleasure cruises and a couple track days a summer which include a 400 kl highway round trip.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
E85 oil change interval Qwimby1 Engine, Exhaust, Transmission 5 07-26-2019 05:04 PM
Oil Change Interval BunnyRZed Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 01-01-2018 09:58 PM
Oil change interval tayj89 Other Vehicles & General Automotive Discussions 3 07-21-2016 10:21 AM
10K oil change interval on 2015's? torqdork Scion FR-S / Toyota 86 GT86 General Forum 29 08-13-2015 01:01 AM
Oil Change Interval Change (Subaru recommended) Flow Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 34 09-10-2014 07:27 PM
