Old 07-22-2025, 06:06 AM   #1
BishamontenZC6
Drives: '14 BRZ Limited
Cusco Power Brace rear member bolts
Hi all ! I just got a 2nd hand set of Cusco rear braces for cheap in Japan :
CUSCO Power Brace Rear Member Side (965 492 RS)
Unfortunately, it didn't come with the mounting bolts. Before I start the installation, can anyone tell me if they can be mounted with the stock bolts or if they need longer ones ?
Many thanks for your help
BishamontenZC6 is offline   Reply With Quote
Old 07-22-2025, 01:38 PM   #2
Compelica
Compelica's Avatar
Drives: 86 GT
Was it supposed to come with mounting bolts? I recall mine did not.
DIY stuff at Compelica Works
Compelica is offline   Reply With Quote
Old 07-22-2025, 05:10 PM   #3
BishamontenZC6
Yes, the original kit normally includes 2 bolts for the LCA side. The other side attaches directly with the stock existing bolt.
Apparently it needs a slightly longer bolt on the LCA side as the cylinder shaped end of the brace it a few millimetres thick. I think I can get away with it by using the leftover OEM LCA to knuckle bolts that I no longer use since I have camber adjustable SPC LCAs with eccentrics. They are slightly longer than the OEM LCA to subframe bolts so it should work in case the regular ones are too short.
Old 08-01-2025, 08:54 AM   #4
Compelica
Compelica's Avatar
Drives: 86 GT
You're right - was checking thru photos and there were M12 bolts provided. The instructions state an M12 80mm partially threaded hex bolt with washers, so that's easy to find.
Any idea what the thread pitch and grade of the bolts are? Asked Cusco and they told me to buy new ones from them...
Old 08-01-2025, 12:04 PM   #5
smackrel
Full Throttle!
Drives: 17 CBSP Limited PP
Not sure about the size of the bolts, but I would wonder how much Cusco would charge for those 2....?
smackrel is offline   Reply With Quote
Old 08-03-2025, 04:46 AM   #6
Compelica
Compelica's Avatar
Drives: 86 GT
Found the answer to my own question - they are 1.25mm in 10.9 grade.
The Following User Says Thank You to Compelica For This Useful Post:
SuperTom (08-03-2025)
Old 08-04-2025, 05:45 AM   #7
BishamontenZC6
Coming back with the solution after installing the braces a few days ago, for those who will come after. Everything worked fine with the OEM LCA to knuckle bolts. They are a little bit shorter than 80mm but were ok.
I can't emphasize enough how much of an improvement those braces bring on the rear axle. More direct transmission of the torque to the road even from low rev, better curve exit stability and a global more solid behavior on bumps. For the price of them, that's 10/10 for me.
Old 08-04-2025, 10:18 AM   #8
Compelica
Compelica's Avatar
Drives: 86 GT
I used to have them on, they made the rear feel much more unified; one of the best Unfortunately I had to take them off as I got the MCA traction mod which occupied the trailing arm mount; it would not fit.
However I've seen similar braces which mount onto the lower arm similar to the Cusco, but instead mounts onto the rear subframe on the other end. Pretty cheap as one of the companies manufacturing these bars is where I live, but not sure if it will have the same effect.
FS: Cusco Power Brace Front, Rear, Rear-side Member and Engine Room fungus Canada Classifieds 2 05-20-2016 12:36 PM
FS: Cusco Front Strut Tower Brace with Master Cylinder Brace / Adj Chassis Brace VoiD Brakes, Suspension, Chassis 2 03-16-2016 05:19 PM
Cusco Front Strut Bar with MC stopper and Cusco Power Brace edsbreezy Brakes, Suspension, Chassis 2 03-07-2014 12:06 AM
anyone install cusco front member power brace? three3y3wrbbrz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 05-03-2013 01:49 AM
