#85 | |
Drives: 2013 Scion FRS & 2022 GR86
Sent from my SM-G920I using Tapatalk
2013 Scion FRS 2022 Toyota GR86 |
| The Following User Says Thank You to Exrald For This Useful Post: | humfrz (05-03-2017) |
#86 | |
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | humfrz (05-03-2017), Ultramaroon (05-02-2017) |
#87 | |
Proud of BOXER
Drives: Subaru Boxer
Nice cat.
Crap, he traded with me too! I remember his car feeling great above 4k, especially with that catless header. Then he told me afterwards he was in 4th gear through the corners I was going through in his in 2nd and 3rd. O.O
| The Following User Says Thank You to Clipdat For This Useful Post: | Ultramaroon (05-02-2017) |
#88 | |
Wish he still hung out here. I Miss him.
#89 |
Drives: 2019 BRZ Premium
There have been a lot of replies on this topic, but I'd like to put in my opinion as well.
12mph is about 20km, you'll bet I'm still in 1st gear during upshifting. I have accelerated in 3rd at this speed. I wouldn't consciously do that again. IMO, either 1st or 2nd gear is fine at this speed. I haven't had this car for long. I have 2800km on the odo. In general I find the car happiest when I stay above 2500RPM. Yes I sometimes go lower when I'm not putting much stress on the engine, e.g. going down a slight hill. The reason why I always try to keep it at at least 2500 RPM is that under that RPM, I can often hear what sounds like early detonation when I try to accelerate. It almost doesn't happen when I'm above 3000 RPM. In short, if I'm going on flat ground, I cruise at about 2500-3000 rpm. When going uphill, I'm never under 3000 rpm. When going downhill, I sometimes go as low as 2000 rpm, or I downshift 1-2 gears to utilise the engine breaking while staying at the speed limit. I haven't noticed a difference in fuel economy when driving at 2-2.5kPM vs 2.5k-3kRPM, but your experiences may vary. When in doubt, always go to a lower gear. |
#90 | |
You probably hear the sound of the free gears rattling in the gearbox. It's really nothing. I regularly idle along in first or second as low as 1000 rpm when in slow traffic. Just avoid stomping on it.
#91 |
Throttle control
RPM Road speed Gear choice If you think about these things, and you understand the reasoning of why you are thinking about these things, you will be golden. Me, I just wring it's neck, or, when stuck in traffic, use the above principles. Disclaimer: I give no cares for fuel economy, my cares revolve around induction, spool and a nice sound coming from the exhaust.
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
| The Following User Says Thank You to 86MLR For This Useful Post: | soundman98 (02-18-2020) |
#92 | |
| The Following User Says Thank You to gravitylover For This Useful Post: | Ultramaroon (02-18-2020) |
#93 |
Drives: 2019 Subaru BRZ
Gear Shift Indicator tables (gen1)
After years of investigating, I think I have found the gear shift indicator thresholds; they would be useful for estimating when "lugging" could occur, but they're calculated in part using the engine load, which isn't shown on the dashboard anywhere. This isn't a perfect answer to the original question, much less the years of debate since then, but it's helpful for estimating, because it specifies a clear range of rpms at which the car would suggest you upshift; at higher rpms in lower gears or on an uphill incline, at lower rpms in higher gears or on a downhill incline.
The process for firing the GSI in gen1 is: - given the engine's current load (0.0-1.5) - multiply it by a correction factor based on current gear (1.35x, 1.15x, 1.00x, 0.85x, 0.80x for 1st-5th) - look up the threshold in the load-to-rpm table (1600-3000rpm) - if your rpm is at or above the threshold, and your speed is 10km/h or higher, trigger the GSI That's a lot of calculations to ask of people that are driving, which is why they reduce it to a flashing light, but there's some useful derivations here. Subaru is unlikely to have programmed the car to tell you to upshift into damage-inducing lugging so long as your goal is to maintain your current speed at your current load after shifting, so these values provide a safe guideline for coasting without lugging assuming no change in road incline. My engine idles at 0.18 load, so my absolute minimum upshift speeds assuming a vertical downhill incline (gravity's doing all the work but my wheels are turning) are from 1st->2nd at (0.18 * 1.35) = 0.243 -> 1875rpm, ..., 5th->6th @ 1600rpm. Looking at a random datazap log trimmed to >1600rpm, typically I only see load 0.1 when I let off the gas altogether and usually I'm at load 0.25-0.3, so for practical purposes that's (uncorrected) 1800rpm; which, after correcting for gear- Minimum upshift thresholds assuming NA gen1, flat level road, no significant headwind, and very tentative estimates on the resulting rpm after the shift: 1st->2nd @ 2400rpm -> 1500rpm 2nd->3rd @ 2100rpm -> 1450rpm 3rd->4th @ 1800rpm -> 1400rpm 4th->5th @ 1500rpm -> 1250rpm 5th->6th @ 1450rpm -> 1150rpm In each case, these should leave you not lugging the engine so long as you just maintain the speed you shifted at. Which means, yes, you can absolutely end up in 6th gear at ~1100rpm without lugging the engine so long as you don't ask anything more of it other than just staying the course. (In practice, this is likely to demonstrate just how not level most roadways are.) So, given that shifting pattern and my napkin estimated rpm conversions - and keep in mind these are very, very approximate, so I may come back and redo this formally with a spreadsheet later: Minimum downhill rpm for each gear, assuming you're coasting downhill with your foot off the gas and the headlights and air conditioner are off: 2nd gear: 950rpm 3rd gear: 1100rpm 4th gear: 1250rpm 5th gear: 1200rpm 6th gear: 1100rpm Minimum level rpm for each gear if you're trying to coast at a given speed on a level surface: 2nd gear: 1500rpm 3rd gear: 1450rpm 4th gear: 1400rpm 5th gear: 1250rpm 6th gear: 1150rpm Minimum max load capable rpm for each gear, assuming either a vertical incline or you wish to be able to floor it without lugging at any time: 2nd gear: 1800rpm 3rd gear: 2100rpm 4th gear: 2300rpm 5th gear: 2400rpm 6th gear: 2350rpm Practically speaking, you're probably not upshifting into the highest possible rpm and then expecting to floor it, but hopefully this provides a better sense than just 'you'll know it when you feel it' or 'only shift at 4000rpm' or whatever. And if that's all too complicated, TLDR: lugging in 2nd-6th at sea level on 91oct is below 1200rpm downhill, 1500rpm level, 2400rpm steep uphill. (Oh, and you can always upshift at 3000rpm without lugging it, apparently.) Last edited by callisto; 08-01-2025 at 02:01 AM. |
| The Following User Says Thank You to callisto For This Useful Post: | tomm.brz (08-04-2025) |
| Low RPM rattle when "lugging"? | topazsparrow | Issues | Warranty | Recalls / TSB | 61 | 05-31-2018 03:10 PM |
