Old 07-17-2025, 12:25 PM   #1
KxngCorey
KxngCorey's Avatar
Drives: Hot Lava FR-S
P0300 P0301 p0171 P119F P219A p1170
IM still running into issues. Same Idle misfires and the occasional stutter when i gas from a dead stop. absolutely no misfires under boost or heavier throttle. Misfire travels throughout cylinders. Some days its 1 or 2 or 3 or 4. I've cleaned injectors (both), done compression test, plugs coils everything.
Please take a look at my datazap. Car still runs fine except the misfires. ITs crazy that this has been a years worth of misfires and the car still runs but im hitting a wall om rectifying this issue. Its getting more and more complicated for me to pass inspection as well here in NY. ANY help would be greatly appreciated
https://datazap.me/u/kxngcorey
P0300
P0301
p0171
P119F
P219A
p1170 <<----NEW CODE. NEVER SEEN THIS IN MY LIFE LOL
2015 Hot Lava FR-S IAG 800 FBM Turbo Kit
KxngCorey is offline   Reply With Quote
Old 07-17-2025, 12:26 PM   #2
KxngCorey
KxngCorey's Avatar
I forgot this is a IAG 800 w/ built heads and stock Cams.
Old 07-18-2025, 06:56 AM   #3
54fighting
Drives: 2020 toyota 86
Have you tried a new battery?
54fighting is offline   Reply With Quote
Old 07-18-2025, 03:58 PM   #4
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
How much Googling have you done? This pops up pretty quick:
https://www.ft86club.com/forums/showthread.php?t=148424
Old 07-21-2025, 05:01 PM   #5
KxngCorey
KxngCorey's Avatar
Too much tbh. So far ive done Vacuum leak check, compression test, changed all the gaskets, cleaned the the direct injectors, cleaned the port injectors, changed spark plugs, got new coil packs, changed cam sensors. im stuck
The Following User Says Thank You to KxngCorey For This Useful Post:
blsfrs (07-22-2025)
Old 07-22-2025, 09:47 AM   #6
blsfrs
blsfrs's Avatar
I had p219 and p119s on a built na engine but could never find the source. My tuner finally just deleted the codes. I've had the misfire and other codes with a vacuum leak.
Did you new gaskets include exhaust? Was you vacuum leak test with smoke?
Old 07-22-2025, 04:21 PM   #7
KxngCorey
KxngCorey's Avatar
Yes with smoke. and new exhaust gaskets. i know some people see the misfires but dont feel/hear them but i do with mine on occasion.
blsfrs (07-22-2025)
Old 07-22-2025, 11:48 PM   #8
blsfrs
blsfrs's Avatar
This guy's problem seemed to be partially solved by putting stock flywheel back in.
https://www.ft86club.com/forums/showthread.php?t=99994
P0301, P219A, P119F, P119E BrZ_Good Issues | Warranty | Recalls / TSB 10 04-16-2025 11:33 AM
CEL P0171, P1170, & P219A Feargt86 Software Tuning 3 03-02-2021 03:53 PM
P219A, P119F - Air Fuel Ratio Imbalance hui202 Issues | Warranty | Recalls / TSB 14 08-16-2019 07:47 PM
P0302, p219a, p0352, p119f, used car woes. Dara321aaa Issues | Warranty | Recalls / TSB 8 04-29-2019 10:44 PM
Click/clanking sound w/ P219A, P119F, P0302 Kentoxik Issues | Warranty | Recalls / TSB 7 01-24-2019 10:23 PM
