Old 04-21-2025, 06:53 PM   #1
Sam_
Drives: 2013 Scion Frs
Rear Quarter Panel Crack
Hi,
I bought my 2013 FRS knowing it had a small crack on the passenger side skirt. Long story short there was a spot on the interstate where there was a bump that caused the bottom of my car to slam on the road and it worsened from there. It looks like someone may have tried to do some sort of bondo repair on this spot before. I am considering my options of doing my own bondo job, taking it to a shop or potentially just throwing a body kit on it. Ideally I want to keep cost as low as possible but know that regardless it wont be cheap. If anyone has any ideas I am all ears.
Sam_ is offline   Reply With Quote
The Following User Says Thank You to Sam_ For This Useful Post:
humfrz (04-24-2025)
Old 04-21-2025, 07:57 PM   #2
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Looking at paint quality,(lack there of) the entire quarter panel has had body work done. A crack like that indicates there's a lot of bondo underneath which could be hiding something worse.
That panel needs to be taken down to bare metal to assess the damage. The bondo is failing and applying more won't fix the issue underneath.
The Following 8 Users Say Thank You to RToyo86 For This Useful Post:
AJ32162 (04-23-2025), Busybee (04-21-2025), JD001 (05-14-2025), Opie (04-29-2025), RT-BRZ (04-21-2025), SuperTom (04-29-2025), Wally86 (04-22-2025), whataboutbob (04-22-2025)
Old 04-24-2025, 10:42 PM   #3
It will buff out -
JD001 (05-14-2025)
Old 04-25-2025, 10:07 AM   #4
AJ32162
Drives: 2019 BRZ with Performance Package
It will buff out -
You must have a one-of-a-kind buffer.
AJ32162 is offline   Reply With Quote
The Following 2 Users Say Thank You to AJ32162 For This Useful Post:
humfrz (04-25-2025), JD001 (05-14-2025)
Old 04-25-2025, 02:44 PM   #5
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Is the car a "salvage"? I'd be worried that amount of body flex.
Old 04-25-2025, 07:37 PM   #6
Originally Posted by AJ32162 View Post
You must have a one-of-kind buffer.
Ahhhhh.......yep!
Old 04-28-2025, 08:45 AM   #7
Tokay444
No that you know that car is garbage, you should throw it in the garbage.
Old 04-28-2025, 05:05 PM   #8
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Call your insurance and see if they can help. It needs professional help. Maybe a quarter panel replacement.
Old 05-07-2025, 11:32 PM   #9
jamie0404
Drives: Toyota
Sam, since the damage appears to be worsened by a previous poor repair, a DIY Bondo fix could be a cost-effective short-term solution if you're comfortable with some sanding and painting.
jamie0404 is offline   Reply With Quote
Old 05-14-2025, 12:52 PM   #10
JD001
JD001's Avatar
Drives: Subaru BRZ
It will buff out -
Its a special, take the head off and it'll keep on buffing till sunrise...
WTB Quarter Panel/ Rocker Panel/ Fender mistergrafik Want-To-Buy Requests 3 11-15-2016 05:34 PM
Rear quarter panel replacement sero901 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 09-25-2015 12:41 PM
Camber and spacers saved my rear quarter panel!!!! suaveflooder Off-Topic Lounge [WARNING: NO POLITICS] 8 01-03-2014 12:37 AM
WTB FR-S RIGHT REAR QUARTER PANEL Billylammerkins Exterior Parts (Aero, Lighting, Etc.) 7 01-01-2014 10:21 PM
Scratch + dent on rear quarter panel - fix or no? rawbz Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 10 08-26-2012 11:50 AM
