Old 03-05-2023, 12:32 PM   #29
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
If you want to make a spacer like the versus one, with offset studs, you may be able to use the threads on the broken stud as is. you can make the counterbore much deeper, i doubt you need more than 2-3mm of aluminum to get the strength you need out of it.
The Following 3 Users Say Thank You to Yoshoobaroo For This Useful Post:
NoHaveMSG (03-06-2023), pym19109 (03-06-2023), Ultramaroon (03-05-2023)
Old 03-05-2023, 04:32 PM   #30
Originally Posted by pym19109 View Post
if I need a CAD file I will PM you
Just keep this thread going. That's why we're all here. I love seeing someone else's creative solution as much as my own. I appreciate the desire to mimimize irreversible work too!
NoHaveMSG (03-06-2023), pym19109 (03-06-2023), soundman98 (03-05-2023)
Old 03-06-2023, 12:15 PM   #31
pym19109
WRBLUE BRZ
pym19109's Avatar
Drives: 2016 Subaru BRZ
That's a good idea! I measured it. the broken stud is only 5-6mm left with 2mm thick of counterbore it will be 3-4mm for thead. Is it ok for that?
pym19109 is offline   Reply With Quote
Old 03-06-2023, 12:59 PM   #32
Rule of thumb is for threaded contact to be as deep as the diameter. Would be close but maybe ok.
pym19109 (03-07-2023)
Old 03-06-2023, 04:44 PM   #33
Yoshoobaroo
TRACKBREAD
If you can get 3 threads on there I would feel comfortable with it.
The Following 2 Users Say Thank You to Yoshoobaroo For This Useful Post:
pym19109 (03-07-2023), Ultramaroon (03-06-2023)
Old 03-06-2023, 04:50 PM   #34
I've called it good with less and a dab of loctite.
norcalpb (03-08-2023), pym19109 (03-07-2023), Yoshoobaroo (03-06-2023)
Old 03-07-2023, 07:26 AM   #35
pym19109
WRBLUE BRZ
pym19109's Avatar
I forgot that lower stud is 25mm long. 10mm spacer is not enough to hide that stud under pedal if I want to make it like Verus (my car is rhd)
Old 03-07-2023, 06:03 PM   #36
Yoshoobaroo
TRACKBREAD
well you shortened the other one somehow
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
Old 12-20-2024, 03:29 PM   #37
Tar
Drives: White gt86 2014 JDM
i got the same problem
2024 anyone can help ?
Tar is offline   Reply With Quote
Old 12-20-2024, 03:57 PM   #38
RT-BRZ
RT-BRZ's Avatar
Drives: 2013 Subaru BRZ
There are a couple of kind of "Nutserts" out there. There are the ones that have a small diameter expansion and then there are the ones that spread out a lot.
Here is a pic of the large flange type: Split Side Nutsert
You could always just drill out the spot welds on the bracket and put a new stud in there. That's harder though. Nutsert is probably the best way to go.
Be careful and don't drill a hole through the floor.
RT-BRZ is offline   Reply With Quote
Old 12-21-2024, 12:22 AM   #39
Tar
Bolt part no. 901380002 buy it at Subaru
Cusco Pedal Install & Pedal Lateral Stiffening (Sideways Loose Pedal) BOND007_LTK DIY (Do-It-Yourself) Guides 5 05-20-2022 05:12 PM
Beastronix pedal box, Nardi Gara Sport 350mm, Velox and Cusco pedal brackets etc. captain awesome Interior Parts (Incl. Lighting) 2 04-21-2021 11:56 AM
FS: OEM Pedal Box MicheleAbbate Interior Parts (Incl. Lighting) 14 02-26-2020 03:02 PM
Painting pedal covers + dead pedal iconic DIY (Do-It-Yourself) Guides 4 12-22-2019 01:39 AM
Gas pedal tintumz22 Scion FR-S / Toyota 86 GT86 General Forum 12 08-22-2012 10:42 AM
