WRBLUE BRZ
Drives: 2016 Subaru BRZ
Hi guys,
I just removed my pedal to install Cusco gas pedal. While I'm putting everything back, It's quite small space for turn the wrench so I keep turn it because I can't feel the tight and accidentally I over tighted the upper bolt. It's broke into piece like the pictures below. ![]() Any suggestion to fix it? |
TRACKBREAD
Oof that’s a tricky one.
You could try and knock what’s left of the stud out and then see if you can bond a new one in there? You could also drill it out and slide a nut in from the backside, then thread a piece of threaded rod into the nut. You could also drill it out, install a rivnut, and then use a bolt or threaded rod in the rivnut. |
Drives: Crapcan
Hard to tell from the pictures, but you may be able to get a rivnut in there that will work.
TRACKBREAD
#5 | |
Drives: Crapcan
WRBLUE BRZ
Thanks for the suggestions.
Will rivnut fits in side tiny space in the back of bracket? or just weld a stud in will it work? |
#7 | |
Drives: Crapcan
I don’t have a solution, but for small things like this I like to take an extension and the 10mm socket to use as a compact screw driver.
#9 | |
Drives: Crapcan
#10 | |
not playing cards
Nut drivers have their place but socket+extension is way more versatile. Some extensions are knurled for just that reason.
#11 |
The Fail Boat
Drives: CWP S.B.
#12 |
Drives: Crapcan
20-25nm is boarder line too tight for those. 6mm mid grade fastener should only be like 8ftlb which is like 10-11nm.
#13 |
WRBLUE BRZ
After I did a search for similar problems, there is not much information for me. I will try to hammer the stamped stud out first (maybe with a extractor also) and wish the god of subie is kind to me XD. if not, cutting the leftover piece and drill will be my only option but this will be a difficult job for sure with a little room there and yes like many of you said "ONLY HAND TIGHT ANYTHING INSIDE THE CAR"
#14 |
not playing cards
It's not so much inside-versus-outside. Everyone has over-torqued fasteners. Everyone has cross-threaded fasteners. The lesson here is to understand that it's natural to want to get in there an really cinch it down tightly so it doesn't come loose. We must learn to fight that urge.
For newb friends I've had under my wing, I put old screws in the vise and had them turn nuts slowly until they strip. Materials vary. Aluminum is super tricky because the threads yield - begin to strip - more gradually than steel. Use a torque wrench. That one will be a bitch. Cut the weld stud down flat. Drill & tap to 6x1.0 mm thread. You might need a bottom tap to finish the job but it's doable. Cut a hex head cap screw to the correct length and clean the threads until it starts nicely.
| Cusco Pedal Install & Pedal Lateral Stiffening (Sideways Loose Pedal) | BOND007_LTK | DIY (Do-It-Yourself) Guides | 5 | 05-20-2022 04:12 PM |
| Beastronix pedal box, Nardi Gara Sport 350mm, Velox and Cusco pedal brackets etc. | captain awesome | Interior Parts (Incl. Lighting) | 2 | 04-21-2021 10:56 AM |
| FS: OEM Pedal Box | MicheleAbbate | Interior Parts (Incl. Lighting) | 14 | 02-26-2020 02:02 PM |
| Painting pedal covers + dead pedal | iconic | DIY (Do-It-Yourself) Guides | 4 | 12-22-2019 12:39 AM |
| Gas pedal | tintumz22 | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 08-22-2012 09:42 AM |
