Old 09-08-2024, 09:28 AM   #15
Ohio Enthusiast
Drives: 2018 BRZ
Final update (I hope) - after 100 miles, the left side boot indeed started leaking at the big clamp (flinging blobs of good grease around), and the small clamps continued to seep a bit of liquified grease.
Took the axles off the diff, disassembled the diff side CV joint, replaced the boot and clamps with the Subaru kit and used Redline CV-2 instead of the Subaru grease. I was lazy and did it on the car (without removing the axle nut and pulling the axle from the hub), but that was just fine and saved me the hassle of dealing with the axle nut.
I started from trying to drop the diff, but that didn't work out so well and started leaking diff fluid (as I couldn't keep the diff level). Bolted the diff back to the car and instead went from the hubs - two bolts removed and it was pretty easy taking the axles out of the diff.
The biggest struggle was actually getting the axles back into the diff. At first I hammered on the hub side (piece of wood on the axle nut), but that didn't do much. Then I hammered a large screwdriver on the small lip on the axle at the diff side and that went right in.
Old 09-12-2024, 09:13 AM   #16
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Just to note, leakage will also occur if you put too much grease in the boot. It actually takes very little.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 09-12-2024, 10:18 AM   #17
Ohio Enthusiast
Drives: 2018 BRZ
I packed the same amount as the Subaru grease bottle that came with the kit - 130 grams. Is that excessive? So far (about 100 miles) there's no grease leaking out.
Edit: now that you mention it, the repair manual specifies 80-90 grams on the CV joint itself, and an additional 20-30 grams in the boot. I think I probably did less on the CV joint and more in the boot, but hopefully that'll even out when driving.
Note to self - thoroughly read the instructions in the repair manual instead of trying to figure stuff on my own...
The Following 4 Users Say Thank You to Ohio Enthusiast For This Useful Post:
BatStig (09-16-2024), blsfrs (09-13-2024), Opie (09-12-2024), Ruben_86_ (09-15-2024)
Old 09-12-2024, 04:24 PM   #18
Opie
Opie's Avatar
I've seen others pack it full....then wondered why it came out....lol.
The Following User Says Thank You to Opie For This Useful Post:
Ohio Enthusiast (09-13-2024)
Old 09-13-2024, 11:05 PM   #19
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I've seen other pack it full....then wondered why it came out....lol.
A couple of years ago, I put too much grease in and it came out when the cup got hot. So much for trying to eyeball it.
The Following User Says Thank You to blsfrs For This Useful Post:
Opie (09-16-2024)
Old 09-14-2024, 12:04 AM   #20
is it the grease, or air trapped in with it? I don't get grease expanding to the point of squeezing out. Trapped air, however... o.0
blsfrs (09-16-2024)
Old 09-16-2024, 12:01 PM   #21
Opie
Opie's Avatar
I think it's the amount of grease, too much and the rotation forces a clump into one side, making the boot flex until it comes out.
Ultramaroon (09-16-2024)
Old 09-16-2024, 02:58 PM   #22
blsfrs
blsfrs's Avatar
Prolly too much grease. I did the vent tube trick and it still blew. I was the left one. I wrapped my exhaust pipe after the last issue and have been good.
Diff Fluid Leaking after Axle and Axle Seal Replacement jaygushi Engine, Exhaust, Transmission 3 12-21-2023 02:53 PM
Best source for axle boots blsfrs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 09-28-2022 04:58 PM
Dss axle boots riped IsaiahW Engine, Exhaust, Transmission 0 07-09-2022 11:42 AM
AutoStyled - Hand-Crafted Shift Knobs/Shift Boots/Brake Boots Are Now Here! RallySport Direct Interior Parts (Incl. Lighting) 4 06-23-2017 02:37 PM
