#15 |
Drives: Subaru BRZ 2017
one of two things most definitely: Heat soak or fuel system.
You need a live full log. upload to datazap. |
| The Following User Says Thank You to ojuniour For This Useful Post: | Stevedave (08-01-2024) |
#16 | |
what are you using to log? Log as many parameters as possible Anyway I had something similar not too long ago.. Was driving me crazy.. Long story short, it was the Fuel Pump (or could be the regulator) for me. i was kinda having the issue prior to me replacing the fuel pump..but it gets worse after replacing it..but apparently i didn't install it properly. I just replaced the whole fuel pump assembly with a new pump. I took the opportunity to upgrade the pump. Car will start fine and then stall after a while out of no where , it starts right back up .. But then gradually get worse in which i have to wait like 5 to 20 minutes before it starts again. The longer it goes the shorter it stays on and the longer the cranking. You can easily test the fuel pressure by getting a fuel pressure/vacuum tester, unplug one of the Low pressure fuel line (preferrable the one closer to oil filter, plug in to the fuel pressure test.. Put the car into ON position without starting the car. You should see the pressure build up and stay at least or above 35 to 40 psi ( i think can't remember). keep it that way for like 5 minutes or so to make sure the pressure isn't dropping.. My thread: https://www.ft86club.com/forums/showthread.php?t=154165 |
| The Following User Says Thank You to ojuniour For This Useful Post: | Stevedave (08-02-2024) |
#17 | |
I have ecutek so I can't really thoroughly help you with the PID. Are you tuned? |
#18 |
#19 |
Update?
#20 | |
The Injection Mode (fuel system) is pretty interesting though. Fuel System 1 (After Staring engine) = Port Injection ON , Direction Injection OFF Fuel system 2 (between 3k and 5k rpm in closed loop - meaning after fully warmed up) = Port Injection is OFF, Direct Injection is ON Fuel System 3 (usually below 3k rpm) = Both Port and Direct Injection ON Fuel System 4 = Both Port and Direct Injection OFF Reference image attached For status 4 , it means both the Port and Direct injectors are not inactive - or rather not providing fuel...where it's showing up in the logs (which I'm assuming in that moment you will experience stumbling..jerkiness, or stalling as the RPM dips. ( I mean duhh..no fuel is being delivered to the cylinder from ANY of the ports - just look at the logs you will notice it lines up with the rpm dip when you have fuel system 4. Oh and this also causes the 'fuel rail pressure psi' dropping for that obvious reason..I mean no fuel no pressure. I would definitely start looking into the fuel pump /assembly. It's not that difficult to replace and go for cheap preowned on ebay for about $70 USD. Just based on the limited date presented, it definitely point to something in the fuel delivery system... So start tracing wires and hoses in that area. Excuse the typos... |
| Car Stalls at Idle | Stevedave | Engine, Exhaust, Transmission | 0 | 05-13-2024 09:36 PM |
| OFT Stalls on Cold Start | scsftballnum45 | Software Tuning | 15 | 02-17-2019 04:13 PM |
| BRZ down... Stalls right after start | bravedeer | Issues | Warranty | Recalls / TSB | 12 | 09-12-2018 07:39 AM |
| HELP! BRZ 2017 stalls when switching to OL | Muchikori | Software Tuning | 5 | 05-27-2018 12:16 PM |
| FR-S - AT nearly stalls when stopping | WryGuy | Issues | Warranty | Recalls / TSB | 12 | 05-27-2016 04:04 PM |
