Old 07-31-2024, 08:28 PM   #15
Originally Posted by jamestemperante View Post
attached here is a more clear sound / video of the rattle. Pls excuse my toe nails tho. lol
Toe nails look well manicured. No issue there.
It's fine. Engine pulses under load at idle are rattling the free gears as they rotate in the transmission. Press the clutch and they quit rotating/rattling.
Perfectly normal, as @Ohio Enthusiast said.
Old 08-01-2024, 01:04 AM   #16
gpvecchi
gpvecchi's Avatar
Lightweight flywheel causes chattering, and this is normal.
Unfortunately, it's difficult to diagnose it, without removing the transmission.
Old 08-01-2024, 03:54 AM   #17
Oh, FFS. It doesn't need to be a "lightweight flywheel." It's normal no matter what.
humfrz (08-04-2024)
Old 08-08-2024, 05:17 PM   #18
Ignore Your Doctor
Ignore Your Doctor's Avatar
Drives: 2015 BRZ WRB
mine makes the same noise I attributed it to the lightweight flywheel, street clutch and carbon driveshaft. Interestingly enough I noticed that if you rev to around 900-1000 rpm the chatter goes away. So I just had my tuner up my idle from 600 to 950 and the noise is gone completely
Ignore Your Doctor is offline   Reply With Quote
Engine rattle, drivers side engine bay. MikeMont Issues | Warranty | Recalls / TSB 2 01-24-2020 11:27 PM
Ticking/rattling after engine install, turns into...? Alfrz91 Engine, Exhaust, Transmission 0 10-01-2019 02:18 AM
EBC stays on for awhile when engine turns off brosifSmith Software Tuning 3 06-03-2019 02:43 PM
Engine rattle MacJunkie AFRICA 12 04-01-2015 08:12 AM
Moving in neutral....Engine turns off? deedz Issues | Warranty | Recalls / TSB 23 04-23-2013 10:23 PM
