Old 11-09-2023, 02:11 AM   #1
Alfrz
Drives: 13 Scion Frs
Not blowing any hot air from vents
Has always blown hot air super fast, now won't get hot whether it's on recirculate or not, where should I start?
Alfrz is offline   Reply With Quote
Old 11-09-2023, 03:39 AM   #2
The engine.
alphasaur (11-17-2023), humfrz (11-16-2023), x808drifter (11-09-2023)
Old 11-09-2023, 06:57 AM   #3
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
- Does air get hotter towards the passenger side vents?
- If you turn the car on with no engine and the fan at low speed, can you hear the temperature door swing in the vents if you cange the temperature from one extreme to the other?
- If it's already hot, touch the heater hoses, are they hot or cold? On hot/one cold? Both hot? both cold?
- Wait until it's cool. Open the radiator cap. Coolant level? - IF low, check for leaks.
The Following User Says Thank You to RZNT4R For This Useful Post:
Ultramaroon (11-09-2023)
Old 11-16-2023, 01:11 AM   #4
The engine.
B T (01-27-2024), Ultramaroon (11-16-2023)
Old 11-20-2023, 02:09 AM   #5
Is it blowing any air at all or is it just not hot?
Bubba says to cover half of the radiator with cardboard -
(hell, it worked back in the fifties)
Old 11-20-2023, 11:58 AM   #6
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
A good start is to check the coolant system to see if you ran the overflow tank dry and picked up any air into the system. If it's empty or really low, it's a good indication the system needs refilled and burped.
cmiovino is offline   Reply With Quote
The Following 2 Users Say Thank You to cmiovino For This Useful Post:
Alfrz (03-12-2024), x808drifter (11-20-2023)
Old 11-20-2023, 01:03 PM   #7
Come on, @Alfrz, we see that you're logging in. What's the scoop?
Old 11-20-2023, 02:04 PM   #8
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
The "I'm a dipshit and won't admit it." syndrome?
IE: Something super simple like it wasn't even set to hot.
Or the coolant suggestion.
The Following User Says Thank You to x808drifter For This Useful Post:
Ultramaroon (11-20-2023)
Old 11-20-2023, 03:27 PM   #9
I figured it was another drive-by thread, but whatevs. ChatGPT doesn't extend olive branches.
Old 01-27-2024, 04:31 PM   #10
Alfrz
Lol sorry, no clue. It did it once since then, towards the end of a drive the air went cold. Never got any codes or anything
All my controls were in the right positions, trust me I sat in that car for 10minutes trying to figure it out that first night, so honestly wish I had more info for y'all. It just didn't become a problem and I didn't realize this thread was being posted on lol
Old 01-27-2024, 07:38 PM   #11
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
As they suggested above, check your coolant levels. If you're low enough it wont make it to the heater core and will cause additional issues such as overheating. Hopefully its just a little low and didn't burn off through the head gasket.
B T is offline   Reply With Quote
The Following User Says Thank You to B T For This Useful Post:
Alfrz (03-12-2024)
Old 02-10-2024, 02:24 PM   #12
motrek
Drives: 2018 BRZ
How's your engine temp?
I had an old car where the thermostat broke and the coolant always cycled through the radiator, so the engine never warmed up and thus the heater didn't work.
motrek is offline   Reply With Quote
Old 03-12-2024, 09:38 PM   #13
Alfrz
To update this, I never did end up checking my coolant since the issue went away and never came back...
Until yesterday it didn't work again.
This morning I got a CEL light and traction turned off, P0128 and P0125. Coolant was probably almost bone try because it took a little over a gallon straight to the radiator. Car wouldn't turn over til codes were cleared, back in action now
Old 03-12-2024, 11:09 PM   #14
Dear God, man! Was your temp gauge not pegged?
whataboutbob (03-13-2024)
Center dash vents stopped working/ blowing Dake Issues | Warranty | Recalls / TSB 12 07-06-2023 08:35 PM
Air blowing out of vents with AC/fan off??? StraightOuttaCanadaEh Issues | Warranty | Recalls / TSB 16 07-11-2017 10:57 PM
TRADE: Indianapolis area, BRZ DGM fender vents for FR-S asphalt vents Evil Minion Exterior Parts (Aero, Lighting, Etc.) 1 05-10-2015 07:52 PM
Is this normal - Hot air blowing in through vents? Lebby83 BRZ First-Gen (2012+) — General Topics 23 05-19-2014 08:58 PM
Did the issue with the air vents blowing hot ever get resolved? fiveoneoh Scion FR-S / Toyota 86 GT86 General Forum 25 09-05-2012 02:21 AM
