Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 08-19-2023, 12:36 PM   #1
tiger1964
tiger1964's Avatar
Drives: 2023 BRZ
Mounting the license plates?
OK, time for the temp tags to come off.
(a) The rear temp was held on with really short sheet-metal screws in the plastic. Really? That suffices?
(b) On the front, two relatively large diameter hole, no threads. Are there threads keeping inside to engage? Nuts from the back?
Is there a better way? I am contemplating breaking out the Riv-nut tool and having nice, positive threads for real bolts. Thoughts?
1964 Sunbeam Tiger, 2015 Porsche Boxster, 2023 Subaru BRZ
tiger1964 is offline   Reply With Quote
Old 08-19-2023, 03:35 PM   #2
ruturaj001
Drives: BRZ 2023
You need SOA342L171 to use those holes and fit US license plate. It's not very straightforward install, the Subaru dealership employee couldn't figure it out and was doing stupid things and said it can't be done without drilling holes. So don't rely on them, pretty easy install once you figure out how to.
ruturaj001 is offline   Reply With Quote
Old 08-19-2023, 05:04 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
if you've got riv nuts, those would definitely be a better option.
Old 08-19-2023, 06:24 PM   #4
tiger1964
tiger1964's Avatar
Drives: 2023 BRZ
Thanks, a search showed a mounting plate... but no mention of hardware?
Looking better all the time. Combined with stainless steel bolts and anti-seize due to dissimilar metals.
BTW, just for fun, ordered a 21"w "euro" plate with her vanity plate number and state flag, I think it will look better on a pointy-nose car like the BRZ than the usual US "billboard". Had one on the Boxster for nine years now, no trouble.
Old 08-19-2023, 08:20 PM   #5
ruturaj001
Drives: BRZ 2023
It will be in the box.
Old 08-19-2023, 11:08 PM   #6
mycrors7
mycrors7's Avatar
Drives: zd8 brz
2022 models had nutserts in those empty holes. you can do the same, or use a wellnut alongside using a jdm to usdm plate adapter
mycrors7 is offline   Reply With Quote
Old 08-20-2023, 08:54 AM   #7
tiger1964
tiger1964's Avatar
Drives: 2023 BRZ
Thanks, and I learned a new technical term :wellnut. I presume a careful measurement of the hole with the digital micrometer, and an order from Amazon, "and Bob's your uncle".
Old 08-20-2023, 10:46 AM   #8
soundman98
soundman98's Avatar
i believe you can order stainless rivnuts as well
Old 08-20-2023, 01:37 PM   #9
tiger1964
tiger1964's Avatar
Drives: 2023 BRZ
or use a wellnut
OK, front hole is a whisker over 8mm, looking online at size charts that's an M4 well nut. Small diameter bolt, but I found M4 Allen-key washer-head bolts so that helps the bolthead not pulling though the plate and mount.
OK, that's Plan B if the wellnuts fail. With stainless screws, no "dissimilar metals" problems.
BTW, with the rear plate just screwed into plastic, can I drill out the bumper cover and add wellnuts there? I am unsure what's behind there, would not want to drill through a brake line, etc. I guess I could wait; I suspect the bumper cover needs to come off to install the trailer hitch eventually, but if anyone is familiar with that part of the car -- please chime in!
Old 08-20-2023, 03:07 PM   #10
Mike Roadway
Drives: 2023 BRZ Limited 6MT
Use traditional screws for the back — available at any autoparts store.
For the front, I used this $15 easy and reversible solution from Amazon:
http://https://www.amazon.com/License-Bracket-Subaru-Adapter-Factory/dp/B071WDD936?pd_rd_w=ZheGp&content-id=amzn1.sym.b854a5c2-4475-41f8-a6d4-df92b2868104&pf_rd_p=b854a5c2-4475-41f8-a6d4-df92b2868104&pf_rd_r=PS0VNPXJEW39HJ6NWRNW&pd_rd_wg =yNTU5&pd_rd_r=c70409ea-b067-4a59-aa29-956ea4f9892d&pd_rd_i=B071WDD936&psc=1&ref_=pd_basp _bia_rpt_ba_s_1_sc
Mike Roadway is offline   Reply With Quote
Old 08-20-2023, 04:05 PM   #11
tiger1964
tiger1964's Avatar
Drives: 2023 BRZ
OK, now we have a Plan C. Not sure why I am not in favor of the plastic toggles, as they are a variation of the technology of the well nuts. I do like the Torx bolt idea, even though our cars are garage kept and her workplace is gated.
The well nuts and bolts will be here tomorrow and I'll report back -- success of failure.
I'd still like something better out back, the sheet metal screws are in place at the moment -- but in the year 2023, is that really how things should be assembled?
Old 08-20-2023, 05:57 PM   #12
ruturaj001
Drives: BRZ 2023
You are way overcomplicating this. Just order the part I mentioned, it comes with all hardware, I paid 30 + tax, only thing it lacks is instructions.
Old 08-22-2023, 06:50 PM   #13
tiger1964
tiger1964's Avatar
Drives: 2023 BRZ
OK, front plate holder on and plate installed. M4 wellnuts are barely, in my opinion, big enough -- had to press the plate holder tight again the car to keep it from spinning and then tighten the bolt about forever before I got "bite" and it took a couple of tries (I tagged not he result and it seems well attached). The M4 bolts, buttonhead/washerhead Allen key M4, were small enough in diameter at the head that I worried about pull-through so I used a washer in between. The wellnut's flange means the plate and holder sit about 1/8" proud of the car, there's a little space in there; I have convinced myself that it's OK, aesthetically.
Instead of JDM or USDM plate, I got a Euro-style plate with her vanity plate number; the good news is that the entire plate is higher than the "functional" part of the grill opening so should no affect airflow there. I think the Euro plates look better on a pointy-nosed car.
Old 08-22-2023, 07:21 PM   #14
LRNAD90
Drives: X5 35d, D90, CX-5 Turbo
Plan Z - No Front Tag at all? Looks so much better...
Seems like the underfunded police departments have better things to do than worry about no front plates? Well that is the hope anyway, but its not a backbreaking fine if they decide to tag you, and no points, so maybe worth 'seeing how it goes'..
~Scott T.
'95 NAS D-90 ST
'13 BMW X5 35d
'22 CX-5 Turbo
'?? 86 one day soon?
LRNAD90 is offline   Reply With Quote
How could i go about removing Velox Camber Plates mounting bolts? Spawn_Of_Creation Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-20-2019 08:18 PM
License plate mounting 333Matt Cosmetic Modification (Interior/Exterior/Lighting) 6 11-15-2016 08:29 PM
How are you guys mounting front license plates? SubaSteveDDS Cosmetic Modification (Interior/Exterior/Lighting) 19 07-30-2015 09:07 PM
Options for mounting BRZ license plate? gt8613 BRZ First-Gen (2012+) — General Topics 6 10-13-2014 03:12 PM
where are you mounting your plates??? poormans_LFA Scion FR-S / Toyota 86 GT86 General Forum 28 01-31-2012 05:41 AM
