Old 08-15-2023, 09:47 AM   #15
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Originally Posted by Teseo View Post
Wonder if it drains completely
No. This much oil is left in the pan after draining then removing the Fumoto.
The Following User Says Thank You to blsfrs For This Useful Post:
Teseo (08-15-2023)
Old 08-15-2023, 12:58 PM   #16
Teseo
Drives: frs
Fucking Christ, thats like 2 quarts. Imagine that amount + oil cooler
Old 08-15-2023, 03:12 PM   #17
tiger1964
tiger1964's Avatar
Drives: 2023 BRZ
Originally Posted by dragoontwo View Post
The part number you have is correct for the second gen. It's made by Tokyo Roki.
Well, back from the dealer, paid $9.58 for the filter and $1.67 for the washer (listed as "gasket" on the invoice? OK...) Hmm, while the one on the car had the Roki name, the new one does not and says "Genuine Subaru". Go figure.
no motor ever drains completely. that's why it's important to warm up the motor, and get the particulates to be held in suspension so they come out as soon as possible.
Absolutely. Need to look up jacking disciplines or I could simply drive up on ramps.
The Honda S2000 we just sold was the first car where there was a big deal over tightening the filter to a torque spec instead of "yeah, that feels pretty tight". So, on the BRZ, I need to revisit that? Which of course means I need a filter wrench that the torque wrench plugs to.
Hey, at least I won't be back on the forum asking "hey, where is the oil filter on this car?"
1964 Sunbeam Tiger, 2015 Porsche Boxster, 2023 Subaru BRZ
tiger1964 is offline   Reply With Quote
Old 08-15-2023, 03:35 PM   #18
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Care to post up a picture of it? I'm curious.
Old 08-15-2023, 04:33 PM   #19
blsfrs
blsfrs's Avatar
Maybe a pint. The container is a Hillshire Farms lunchmeat container. I don't remember if it was oven roasted turkey or honey ham. It's not very big. Some folks commented that they cut the threaded end of the valve, so it did not protrude into the pan.
The Following 2 Users Say Thank You to blsfrs For This Useful Post:
DocWalt (08-16-2023), Teseo (08-15-2023)
Old 08-15-2023, 09:54 PM   #20
soundman98
ProCrastinationConsultant
soundman98's Avatar
i don't know that there's any torque spec listed. i always just hand-tighten it.
though as with any oil filter, they're always difficult to get off.
i highly recommend the motivx filter wrench adapter. so much nicer than the flimsy stamped steel pieces.
https://www.amazon.com/dp/B09JRNWYR2...v_ov_lig_dp_it
this funnel kit is also on my to-get list.
https://www.amazon.com/dp/B09X23RHL9...v_ov_lig_dp_it
i got a motivx complete kit for my tacoma(raw filter in an oem housing; kit included filter drain tube, filter housing wrench, and funnel) that includes those 2 things, and it makes the process even less painless than it was before.
Old 08-16-2023, 09:17 AM   #21
tiger1964
tiger1964's Avatar
Drives: 2023 BRZ
Very well, back to hand-tighten then. Thanks for the links to those tools, both are now bookmarked! So far, I'll pass on the Fumoto valve, I am seeing enough web pages on "my Fumoto valve leaks!" and, even if a tiny % of those sold, it's simple enough to use a wrench on the drain plug.
i don't know that there's any torque spec listed. i always just hand-tighten it. though as with any oil filter, they're always difficult to get off.
The Following User Says Thank You to tiger1964 For This Useful Post:
soundman98 (08-16-2023)
Old 08-16-2023, 09:43 AM   #22
dragoontwo
dragoontwo's Avatar
I've had 5 vehicles on fumoto valves(2 on the same valve) with no leaks so far. Only thing I do different is using the factory crush washer instead of the fiber one it came with.
The Following User Says Thank You to dragoontwo For This Useful Post:
blsfrs (08-16-2023)
Old 08-16-2023, 03:33 PM   #23
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
There's plenty of oil left in the pan even with the stock drain, the stamped piece that's welded in to carry the threads is pretty tall.
The Following User Says Thank You to DocWalt For This Useful Post:
blsfrs (08-17-2023)
Old 08-17-2023, 12:06 AM   #24
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
After draining with the fumoto valve, the engine still takes about 6 quarts. Every time. For 7 years. With no issues.
Also: "Build Thread"
blsfrs (08-17-2023), soundman98 (08-17-2023)
Old 10-26-2023, 12:53 PM   #25
tiger1964
tiger1964's Avatar
Drives: 2023 BRZ
Thanks, I followed the link and ordered. Now I am halfway through the oil change, and that 74mm unit from the link is too small and will not fit (neither does my Lisle two-jaw adjustable, so I used a strap type wrench); and, yes, I should have measured it myself before ordering. . Anyone knows the correct size and/or part # for the correct wrench?
Old 10-26-2023, 01:54 PM   #26
tiger1964
tiger1964's Avatar
Drives: 2023 BRZ
OK, done with the 1000 (actually 1226) mile 1st oil change. A few thoughts:
* 29 ft/lb on the drain plug? Uh, someone at the factory might have set it at something much higher, but I got it off. Interestingly, my torque wrench's lowest setting is 26 ft/lb and I wonder if accuracy is less consistent at that end of the range? Anyway, felt right.
* They say ensure not to double up the crush washer. Looking at the plug, I was not so sure, just a silver line under the threads that might have been paint scraped off. After a couple of minutes with a paring knife -- yup it came off, that was the crush washer.
* My Harbor Freight "race jack" got under there, but could not get the car high enough to set either pair of jack stands in the correct spot. I could get another jack but... don't raise the bridge, lower the river. So, Amazon sent jack stands with a lowest setting of 9.5" (only 2 tons, though). Worked like a charm.
* Wow, 0-20 is really low viscosity compared to, say, straight 40 weight. Just pulling the dipstick out, a few droplets went everywhere. Fortunately had a bottle of spray detailer handy. That said, 0-20 is I guess thick enough, it took a long time draining until the last drip-drip-drip ended (20 minutes?)
* 5.3 quarts did not do it. More like 5.7 quarts. The suggested screw-in funnel works great, I recommend getting one -- the clear window means you can really know when the bottle is more or less empty.
Old 10-26-2023, 02:35 PM   #27
dragoontwo
dragoontwo's Avatar
it was likely put on with 29 ft lbs at the factory, but the paint made sure that it wouldn't come off.
Need Help Sourcing An Engine Sojhinn Issues | Warranty | Recalls / TSB 2 08-04-2017 10:43 PM
Help Sourcing Wheels and Matching with Louvers marchocais Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 04-04-2015 11:40 PM
Thoughts on sourcing custom turbo kit raven1231 Forced Induction 16 10-22-2014 02:34 PM
Sourcing new TRD parts Brandon__ AFRICA 8 01-28-2013 04:28 AM
Where will you be sourcing parts for your FRS/BRZ? neveronlinefrs Southern California 9 03-17-2012 06:50 AM
