Old 05-27-2023, 11:43 PM   #1
ruturaj001
Drives: BRZ 2023
Do I need spacers? 2 camber bolts with stock wheels and suspension
I installed whiteline camber bolt on top and SPC camber bolt on bottom on my 2023 BRZ. I can but hardly fit finger in gap between spring and tires on front. Is that enough or I need to get extended bolts and spacers?
ruturaj001 is offline   Reply With Quote
Old 05-28-2023, 03:48 AM   #2
ACT86
ACT86's Avatar
Drives: English, French, Swedish & Japanese
Finger width would be fine IMO.
ACT86 is offline   Reply With Quote
The Following 4 Users Say Thank You to ACT86 For This Useful Post:
JD001 (05-28-2023), Ohio Enthusiast (05-28-2023), ruturaj001 (05-28-2023), ZDan (05-28-2023)
Old 05-28-2023, 09:48 AM   #3
marco_mc22
Drives: Toyota 86
Super fine.
marco_mc22 is offline   Reply With Quote
The Following User Says Thank You to marco_mc22 For This Useful Post:
Old 05-28-2023, 10:55 AM   #4
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
How much camber is that ?
autoracer86 is offline   Reply With Quote
Old 05-28-2023, 11:04 AM   #5
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
I'd make sure you have 10mm (TUV requirement, so safe starting point).
fingers are too variable for measurement.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
ruturaj001 (05-29-2023)
Old 05-28-2023, 11:06 AM   #6
JD001
JD001's Avatar
Drives: Subaru BRZ
I have the following:
20mm front spacer
25mm rear spacer
Camber bolts
Super pro rear arm and toe links
KW V3 - finger space between top of tyre and front wing... All super duper good!!
The Following User Says Thank You to JD001 For This Useful Post:
Old 05-28-2023, 01:11 PM   #7
ruturaj001
Drives: BRZ 2023
Should be about 2.5-2.7°. I am doing alignment next week.
The Following User Says Thank You to ruturaj001 For This Useful Post:
autoracer86 (05-28-2023)
Old 05-28-2023, 03:16 PM   #8
ruturaj001
Drives: BRZ 2023
Would check again. What's TUV?
Old 05-29-2023, 01:02 AM   #9
ruturaj001
Drives: BRZ 2023
20mm front spacer
25mm rear spacer
Camber bolts
I assume you meant distance on outside of the wheel? If so, my question was about inside.
Old 05-29-2023, 01:03 AM   #10
ruturaj001
Drives: BRZ 2023
I checked again, it's very tight, my finger tip fits when pushed, I would say it's about 5mm.
Old 05-29-2023, 03:59 AM   #11
JD001
JD001's Avatar
Drives: Subaru BRZ
Unsure what the distance was when I had the spacers installed while I still had the original dampers but with Eibach sportline springs. I just wanted the wheels pushed out.. oh I had the alignment done at the time.
Old 05-29-2023, 03:47 PM   #12
ruturaj001
Drives: BRZ 2023
I ended up ordering 3mm spacer last night, if alignment guy thinks I need it, I would put those on.
autoracer86 (05-29-2023)
Old 05-29-2023, 03:57 PM   #13
autoracer86
Drives: Toyota GT86
Will you need extended studs as well ?
Old 05-29-2023, 05:42 PM   #14
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
3mm technically clears but doesn't leave much stud left for nut to grab onto. Not sure I'd feel comfortable running that on track but that's me.
Some 2.5" Arps would solve that.
The Following 2 Users Say Thank You to RToyo86 For This Useful Post:
autoracer86 (05-29-2023), ruturaj001 (05-29-2023)
Camber bolts and stock suspension rub Cubix Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 08-02-2021 01:46 AM
20mm & 25mm v3 bolt on spacers. Whiteline camber bolts Newlovekid Wheels and Tires 4 09-01-2014 02:35 PM
Koni/GC Suspension, SPC LCA's, Wilwood BBK, OEM Camber Bolts SportInjected Brakes, Suspension, Chassis 13 08-22-2014 09:52 AM
Front stock struts/bolts max camber Q.. OICU812 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 10-15-2013 05:45 PM
Tein S-Tech, Stock Wheels, Camber Bolts, Alignment. Yes, I've used search already. Shiro86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 08-14-2013 10:44 AM
