Drives: 2013 scion frs
Black soot and rattling noise (Videos and images attached)
I've attached some youtube links to shorts that I've uploaded.
The first link provides the sound I'm hearing. This sound does sometimes go away when the clutch is pressed in. I believe it to be a TOB but I could be wrong. However, it kicks on when the A/C is turned on (shown in video) This confuses me as to how the clutch sometimes effects the issue. https://youtube.com/shorts/lL_mzDVnuaY?feature=share Below are two links to the soot I'm referring to. It looks like it could be oil based off the location and the drip spot shown in video. https://youtube.com/shorts/-FPHOvqTdec?feature=share (second video is just for comparison) https://youtube.com/shorts/DJdkefZEAxo?feature=share ![]() ![]() I plan on taking it in to Toyota soon to have them look at it. I want them to check if it's running rich, inspect the engine block, catalytic converter for damage and a squeak from the engine bay. When I was parked at a drive through the squeak was so god damn loud lol. If anyone has any information/theories/advice that would be super appreciated. 2013 Scion FRS 100k/mi |
#2 |
Drives: 2018 BRZ
How does the serpentine belt look? Worn belt could squeal, and it makes sense that the AC engaging making it worse. If the belt is slowly disintegrating it could be throwing rubber dust around, making it look sooty. Also check all pulleys while you're at it to make sure none are seized/hard to spin, especially the idlers and tensioner.
Edit: now that I actually listened to the video it's not belt squeal. Sounds like engine load dependent, so turning on the AC would make it worse. How are your engine mounts? |
| The Following User Says Thank You to Ohio Enthusiast For This Useful Post: | Clipdat (05-04-2023) |
#3 |
Drives: Crapcan
I can't get over that air filter setup. You went from a factory cold air intake with a panel filter to some aftermarket intake that is picking up hot air from the engine bay. You filter is also not oiled.
That is oil residue. Either timing cover or OCV leak or spill from filling.
| The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post: |
#4 | |
As for an oil leak, that’s what I’m worried about. How would I go about finding the possible leak? Last edited by DigitalFootprint; 05-04-2023 at 02:11 PM. |
| The Following User Says Thank You to DigitalFootprint For This Useful Post: | Ultramaroon (05-04-2023) |
#5 | |
#6 |
https://www.ft86club.com/forums/showthread.php?t=152655
You've been driving it minimally at least since late February. Is that rattle an exhaust leak, or is it your transmission? Does the rattle quit when you disengage the clutch? Writing about it won't help. Gotta get in there and fix shit.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | villainous_frx (05-10-2023) |
#7 | |
ProCrastinationConsultant
first step here is to clean the motor and see if the problem re-appears. as for the rattle, check the exhaust connections and hangers. if the exhaust was replaced at any point, or swapped back to stock before you got it, it could be any of those loose connections.
| The Following User Says Thank You to soundman98 For This Useful Post: | DigitalFootprint (05-04-2023) |
#8 | |
Drives: Crapcan
It's a common oil leak on these engines. You need to pull the engine skid off and degrease the front of the engine to even figure out where it is coming from. That skid plate is supposed to be brushed aluminum and yours is black so it's been leaking for a very long time. If it is just an OCV, easy fix. If it is the timing cover, then you need to determine how bad the leak is and decide if it is worth bothering to fix. Timing cover reseal is an engine out affair and is easy to screw up. You may be able to get away with cleaning very thoroughly and smearing some RTV where it is leaking. As for your noise, i'd want to address that pretty soon. Sounds TOB'ish to me. Neglecting that for too long means replacing the front cover of the transmission too.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | DigitalFootprint (05-04-2023) |
#10 | |
I would like to mention that the rattle seems to appear when the engine has warmed up. It comes and goes. If Im driving with the AC off it can appear but more often than not it’ll rattle when the AC is switched ones (shown in video) Last edited by DigitalFootprint; 05-04-2023 at 04:35 PM. Reason: Clarification and information added |
#11 | |
The TOB has been a concern and what’s mainly been alerting me. I’m writing all of this down to bring to a Toyota shop to see what they say. Thank you 🙏 |
| The Following User Says Thank You to DigitalFootprint For This Useful Post: | NoHaveMSG (05-04-2023) |
#12 | |
#13 | |
Drives: Crapcan
If it's the actual timing cover that is an expensive repair. As a DIY'er it's not an easy repair either so I don't want to recommended someone take it on not knowing someone's skill level. There have been a few people who have bandied it and it's been okay. So I don't feel too bad about saying it.
#14 |
Seems that time spent taking and posting videos is more valuable than actually working on the problem.
| Tags |
| 2013 fr-s, rattling, soot |
| Black soot in exhaust. Normal? | omadab | Engine, Exhaust, Transmission | 37 | 02-03-2019 06:56 AM |
| UEL headers = black soot on exhaust tips? | LaertesSon | Issues | Warranty | Recalls / TSB | 11 | 05-13-2016 09:46 AM |
| high pitched noise when clutch is engaged ( video attached) | jotig | Issues | Warranty | Recalls / TSB | 9 | 07-05-2015 10:22 PM |
| Squirrel noise >1K RPM, Video attached | SubieNubie | Issues | Warranty | Recalls / TSB | 9 | 11-27-2013 12:11 AM |
| Water with black soot in exhaust | KamalT | Engine, Exhaust, Transmission | 17 | 01-08-2013 10:28 AM |
