#71 |
I thought they came with them. I have two sets of four blocks. One a bit taller than the other.
#72 |
Drives: 2018 Subaru BRZ
SARD FRP wing installed. See my instruction guide below.
![]() SARD Wing Install with OEM Holes Covering https://r.tapatalk.com/shareLink/top...ink_source=app
| The Following 3 Users Say Thank You to spcmafia For This Useful Post: |
#73 |
Drives: Toyota GT86
Loving the look of the wing. Thanks for the guide as well
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
| The Following User Says Thank You to autoracer86 For This Useful Post: | spcmafia (04-10-2023) |
#74 |
Hey thank you, and my pleasure!
#75 |
When in Gettysburg
![]() Sent from my iPhone using Tapatalk
#76 |
A few updates;
For about a year, the vehicle started making a metallic, ticking noise. It became more preeminent when the vehicle was warmed up, and would only go away whenever applying little to full pressure to the clutch pedal. I greased everything that I could, did two fluid replacements, nothing changed. Until finally I caved in about the possibility that it might be my throwout bearing (TOB). So I got all my parts together, and went to work. Mind you this was the very first time I took on a more advanced repair by myself. There were a couple of freak moments, but in the end, after countless thread updates and YouTube videos, the repair was finished. Thread here https://www.ft86club.com/forums/show...28#post3579028 I took the opportunity to change fluids and went with AMSOIL. Probably the best decision I've made regarding Engine, Transmission, and Differential fluids. Everything feels so silky smooth and the car feels so much different. Highly recommend to make the switch. New parts installed are: Verus Engineering Clutch Fork and Pivot Revised TOB (OEM) Schaeffler Slave Cylinder Whiteline Transmission Insert
#77 |
Drives: Toyota GT86
I switched over to asmoil as well
just in the transmission at the moment. Like you I found it to be very smooth
| The Following User Says Thank You to autoracer86 For This Useful Post: | spcmafia (05-02-2023) |
#78 |
Site Moderator
Drives: ichi 86 Project
Hopefully you replaced bearing retainer when you replaced the TOB.
| The Following User Says Thank You to ichitaka05 For This Useful Post: | Jdmjunkie (05-02-2023) |
#79 | |
I thought it needed to be replaced but it was in pristine condition. I think I caught the TOB way before it would’ve caused any significant damage.
| The Following User Says Thank You to spcmafia For This Useful Post: | ichitaka05 (05-03-2023) |
#80 |
Bilstein B14 PSS Installed.
| The Following User Says Thank You to spcmafia For This Useful Post: | NoHaveMSG (05-31-2023) |
#81 |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | spcmafia (05-31-2023) |
#82 |
Thought of you <3. I'll upload pics once I get the alignment done today.
#83 |
spcmafia 18 BRZ
So… the shop that I brought the car to get the alignment outright denied to do the work because of their lift? Fearing it would bottom out.
#84 |
Drives: Crapcan
That happens. I would call ahead and ask if they handle lowered cars.
