| BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ |
Sr. Spiritual Advisor
Drives: 2023 BRZ Premium
Base model BRZ - What do you need to bypass airbag light errors with race seats?
I've just replaced the front seats with race seats. The connections are actually pretty simplistic, and there are only seat belt (carried over) AND airbag plugs for driver, and there's also an occupant sensor for the passenger.
Feels like it would be so much easier to just change the driver seat! ![]() The occupancy sensor in orange..
'23 Subaru BRZ Premium Manual (Track Build Thread)
'22 Ford F150 Lariat Powerboost SuperCrew 6'5" 4x4 '21 Tesla Y Long Range AWD '19 Corvette Z06 Z07 (Track Build Thread) Last edited by X25; 10-31-2022 at 03:13 AM. |
| The Following User Says Thank You to X25 For This Useful Post: | Mike_ZN6 (10-31-2022) |
#2 |
Drives: 2016 Toyota 86
I am also curious about the occupancy sensor's method of functionality and how it can be dealt with properly.
#3 |
Drives: 19 86, 22 BRZ
3.3 ohm resistors work fine. Like you said, its way easier to just change the drivers seat.
You're on the right track with the occupancy sensor. I also ordered that same part # hoping its the complete occupancy sensor x4 + harness - Saw on a FB group post that someone took it off their stock seats which required quite a bit of taking apart.
#4 |
Ok here's hoping that harness would be the end of it! Besides the occupancy sensor, the harness also lets you plug in the seat belt plug. I guess you could figure that out without it, but this would make it a clean install. I'll try it out as soon as I receive the part.
'22 Ford F150 Lariat Powerboost SuperCrew 6'5" 4x4 '21 Tesla Y Long Range AWD '19 Corvette Z06 Z07 (Track Build Thread) |
| The Following User Says Thank You to X25 For This Useful Post: | jongers (10-31-2022) |
#5 | |
FYI 64084CC010 - I was able to order this part at my local dealer. It's actually missing the 4 sensors that are attached to the seat rail (only includes the cabling).
#6 |
Shoot, do you know what else needs to be ordered?
#7 |
Anyway, I ran out of patience, and looted my OEM passenger seat for the parts. In short, NO WARNING LIGHTS!
With everything connected, there're no longer any lights!!! I fixed all the sensors by the race seat's base mount to make sure the sensors are not hurt by harness, etc. They are not very well protected as they are. All done!!
| The Following 4 Users Say Thank You to X25 For This Useful Post: |
#8 |
Drives: MR2, Sliver BRZ
occupancy sensors are LIN bus based. They are actually similar to Load cells. So they measure deflection of the weight on them. No real way to bypass them other than unbolting them and leaving them on the floor lol.
I will be working on a device soon that will be able to connect a different sensor into the system. But that will be later on.
Always looking to tinker with something..
| The Following 3 Users Say Thank You to geraldjust For This Useful Post: |
#9 | |
Drives: 2022 Toyota GR86
Are you able to confirm that the passenger airbags work with this setup? i.e. if you sit in the passenger seat, is the "passenger airbag on" light on instead of the off? I have seen similar setups where the occupancy sensor is retrofitted to aftermarket seats and this works, but want to ensure it works in gen 2 as well. |
#10 | |
#11 | |
#12 |
Drives: 2022 BRZ
Another person reporting in who has been trying to kill those lights. I've tried several different resistors in the airbag, seatbelt, and occupancy harnesses. No dice so far. I'm also pulling/reseting codes. I have a friend who just replaced the drivers seat and kept the seatbelts and the resistor approach worked for him.
Mine is track-only so I have everything removed. My next attempt will be to install the sensors from the seats and disable/bypass them 1 by 1. |
#13 | |
Drives: 2023 BRZ, 2018 Golf R 6MT
There are two smaller bolts that attach each sensor to the sliders, and then one larger bolt that connects the sensor to the seat. -Mike |
#14 | |
| The Following 2 Users Say Thank You to geraldjust For This Useful Post: | Code Monkey (04-22-2023), jongers (04-22-2023) |
| Airbag light trick for racing seats. | Ricepuddin | DIY (Do-It-Yourself) Guides | 111 | 03-18-2024 08:05 AM |
| BRZ seats installed into FRS... Airbag Light | Wpomp | Cosmetic Modification (Interior/Exterior/Lighting) | 39 | 03-27-2021 03:07 PM |
| Airbag light from removing Airbag controller - any effect on performance? | Joesurf79 | Tracking / Autocross / HPDE / Drifting | 9 | 03-26-2019 06:06 AM |
| No Race Track Seats in Race Car Drivers Every Day Cars..!! | JohnnyNight | Cosmetic Modification (Interior/Exterior/Lighting) | 24 | 10-16-2012 04:42 PM |
| Hi-res pics & list of BRZ JDM model grades from stripped down base model to STI(?) | switchlanez | BRZ First-Gen (2012+) — General Topics | 68 | 02-14-2012 07:16 AM |
