#15 | |
Drives: Toyota GT86
Maybe I will open my mind to spherical parts when I start upgrading the suspension. Thanks
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
#16 |
Drives: 24 GR Yaris, 23 GR86
Damn it I just installed KTA216A. Wish I knew about those before
| The Following User Says Thank You to MrSkubi For This Useful Post: | norcalpb (04-03-2023) |
#17 |
Drives: Crapcan
In the grand scheme of things, the sphericals on the LCA's are not really a big deal as far as NVH. I didn't really notice them when my car is more stock and I think the subframe bushings do a good job absorbing a lot of the NVH aftermarket suspension components generate. I saw in your other thread you are going to the whiteline subframe inserts, which may cause them to generate more NVH, I dunno for sure. I am on solid subframe bushings along with a bunch of other parts so "NVH" may as well be my car's middle name.
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | autoracer86 (04-03-2023), norcalpb (04-03-2023) |
#19 | |
Drives: Toyota GT86
| The Following User Says Thank You to autoracer86 For This Useful Post: | NoHaveMSG (04-03-2023) |
#20 | |
| The Following 2 Users Say Thank You to norcalpb For This Useful Post: | NoHaveMSG (04-03-2023), Racecomp Engineering (04-04-2023) |
#21 |
Drives: Crapcan
Threads are 16x1.5m, kind of an oddball. Threaded shank is 61mm long and bore center to end of shanks is approx 90mm. Bore is for 12mm bolt and is just under 43mm thick. Mostly posting this for my own posterity when I try to find a spherical that will fit.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Racecomp Engineering (04-04-2023) |
#22 | |
Drives: Crapcan
Another side note, these are like twice as heavy as the RacerX arms they are replacing.
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | Racecomp Engineering (04-05-2023), RT-BRZ (04-05-2023) |
#23 | |
Drives: 2013 Subaru BRZ
![]() Side note; those are my "storage and offseason" tires. I do track the car but if those babies are still good they are kept warm inside the house in the offseason. Here's a pic: Last edited by RT-BRZ; 04-05-2023 at 01:33 PM. |
#24 | |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | RT-BRZ (04-05-2023) |
| Whiteline | IsaiahW | Engine, Exhaust, Transmission | 8 | 12-15-2021 06:38 PM |
| WTB: Whiteline LCA's | Skurj | Canada Classifieds | 0 | 06-21-2017 06:11 PM |
| FS: Whiteline Rear sway bar endlinks, New Whiteline rear swaybar mount braces | e1_griego | Brakes, Suspension, Chassis | 1 | 02-15-2017 12:00 PM |
| FS: Whiteline Positive Shift & Perrin Rear Shifter Bushing + Whiteline Front Diff Bus | neilvosko | Brakes, Suspension, Chassis | 1 | 11-21-2016 02:44 PM |
| FS: Whiteline Rear Toe Arm/ Whiteline Rear Camber Adjust Kit | Quanye | Brakes, Suspension, Chassis | 7 | 02-07-2016 01:55 PM |
