Drives: '13 Scion FR-S
After light city driving, there's visible smoke with a burning smell (in the cabin too) coming from what seems to be a connection to the oil pan. Anyone know what this is? Has occurred multiple times but film was from this weekend.
This is a '13 Scion FR-S ('13 Toyota 86 equivalent outside of the US and Canada). It had an oil pan seal by Toyota (in a different city) 2~3 years ago (paid by me) when they had the engine out for the valve spring recall. See Facebook link for video. https://www.facebook.com/10009156216...41608549245775 |
#2 | |
Proud of BOXER
Drives: Subaru Boxer
That's what you're calling a "connection to the oil pan"? Interesting.
Anyway, the dipstick isn't fully inserted for starters. Maybe it's oil leaking out from that and dripping down onto the header and burning up? Or from the dipstick seal where it goes into the engine block? IIRC that was a common issue.
#3 | |
Was the 'connection to the oil pan' incorrect phrasing? Re: dipstick - Good of you to point that out, I should address that. The dipstick was removed immediately prior to the video to check for the levels for the record, but I should have fully inserted it before filming to not create that ambiguity. |
| The Following User Says Thank You to PeteK For This Useful Post: | Clipdat (04-04-2023) |
#4 | |
Proud of BOXER
I just didn't know what you meant or what you were referring to, because in the video I don't see any connection to the oil pan. The oil pan isn't visible in the video.
Here's some info about the leaking dipstick seal: https://www.ft86club.com/forums/showthread.php?t=133257
#5 | |
Also appreciate the link to the thread. The original Google drive link is inaccessible but there's still some good info and although I didn't notice any oil along the tube, I can't 100% rule out an issue there, especially given fx35s's comment. I'll read up more responses to this thread, if any, and go to a nearby Toyota tomorrow to check it out. |
#6 | |
Proud of BOXER
Get a bright LED flashlight and shine it around the area where the dipstick tube enters the engine, check for signs of oil leaking.
Here's another possibly relevant thread: https://www.ft86club.com/forums/showthread.php?t=103687 Looks like this guy had a bigger leak. Sorry I can't be of more help, but the key is going to be identifying where it is coming/dripping from, if it is indeed an oil leak. In the video there's quite a bit of smoke, so I assume you should be able to see it dripping if it's an active leak.
#7 |
Drives: Crapcan
That’s the front O2 sensor. Was work done to the car recently? Looks like something pooled around the indent where it fits into the header.
#8 | |
#9 |
Thanks for identifying the sensor, and no, no work done recently. The smell was sensed before (but very occasionally and it was never this bad - never saw this smoke before).
#10 | |
Proud of BOXER
You may need to have the engine running while you use a flashlight to look for the leak. Hopefully it's not coming from behind the crank pulley or something.
#11 |
#12 | |
Proud of BOXER
Rgr that. Sorry you're getting a face full of smoke just looking into the engine bay. Definitely not a fun experience.
Fun story for you, back when I purchased my first FR-S in December of 2012, I was driving it for the very first time (didn't test drive it - already knew it was going to feel perfectly amazing) off the dealer lot and got a few miles away to a stop light. Suddenly I notice whisps of white smoke coming out of the right hand side of the engine bay. WTF?! Is my brand new car ON FIRE or something? No no no, that couldn't be. I told myself maybe it's just "release agents" evaporating or something. lol. It ended up being the leaking cam plate on the passenger rear side of the engine, dripping oil down onto the hot overpipe. Flawed from the factory with 13 miles on it! I ended up working with Raceseng to test their prototype cam plate before it was released, and I validated their part's successful fixing of the issue!
#13 | |
Just now I managed to take a look at my FR-S. No visible leaks at idle, but after a 10-minute drive to get more of an oil circulation, I did notice the same* burning smell and what appears to be this puddle (but didn't catch any leaks mid-drip). Edit-add: No visible smoke this time though, nothing out of the ordinary next to the O2 sensor.* Will wipe it tomorrow morning when the sun rises again and see if it reforms. Will also update the thread after going to Toyota (possibly tomorrow afternoon), just hoping to learn from this experience. Edit-add: Went back after it cooled down a bit to wipe it (also to see what it was) because I didn't want to burn myself before (should have maybe used tongs or something in retrospect when it was fresh), but it seems dry - now I'm not sure if it wasn't there before. Again, appreciate your advice, links, and anecdotes. |
#14 | ||
Proud of BOXER
Anyway, looking at the photo you posted, I believe this would fit the description of oil leak from front timing cover, or from the dipstick tube hole. And it looks to have been going on for a while based on the pooling/residue on top of the header. Either way, the Toyota dealer should be able to diagnose and quote you for a repair.
| Tags |
| burn, engine bay, oil leak, smoke |
| Smoke coming from only 1 exit on dual exhaust? | illest | Engine, Exhaust, Transmission | 9 | 01-04-2016 09:01 PM |
| Smoke coming inside from by gear box in to cabinet | 86main | Issues | Warranty | Recalls / TSB | 3 | 02-28-2014 04:32 AM |
| Smoke Coming From Hood When Driving | HD86 | Issues | Warranty | Recalls / TSB | 29 | 02-06-2014 09:31 PM |
| White smoke coming from the exhaust. | hansthegerman | Engine, Exhaust, Transmission | 17 | 10-02-2013 05:23 PM |
| Smoke coming from the Exhaust | peachsnow | Scion FR-S / Toyota 86 GT86 General Forum | 18 | 12-09-2012 03:59 AM |
