Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 03-24-2023, 07:41 AM   #1
KillerBMotorsport
KillerBMotorsport's Avatar
Gen 2 Rear Diff Durability
Not having any issues except for really enjoying wagging the tail in this thing.
It has me wondering if anyone has experienced and rear diff durability issues?
If you did have a problem or failure, were there any initial symptoms or indications that it was starting to go, or did it just outright fail?
Any thoughts of feedback appreciated!
KillerBMotorsport is offline
Old 03-24-2023, 09:00 AM   #2
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
Isn’t it the same part as the first gens? And weren’t the first gen diffs known to be able to handle a lot more power / torque than the stock specs ?
alex87f is offline
The Following User Says Thank You to alex87f For This Useful Post:
Opie (03-24-2023)
Old 03-24-2023, 10:08 AM   #3
KillerBMotorsport
That I don't know, we never owned a Gen 1 car.
Being able to handle a lot of power is good, but cornering, or sliding through corners is what I would think would torch a diff.
I see some of the track guys have upgraded the diff. For improved durability, or for improved locking?
Hopefully I'm concerned over nothing
Old 03-24-2023, 10:16 AM   #4
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Yes.
It's to change to a true LSD with a clutch type lock up.
dragoontwo is offline
The Following User Says Thank You to dragoontwo For This Useful Post:
Opie (03-24-2023)
Old 03-24-2023, 11:21 AM   #5
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
Furthermore it is the same diff that is used in some Lexus vehicles, FWIW...
When I changed the final drive gearing in mine, I spoke at length with a shop that specialized in setting up diffs and they commented how they don't see many of these because "they rarely fail".
Originally Posted by drewbot
Pull out
nextcar is offline
The Following User Says Thank You to nextcar For This Useful Post:
whataboutbob (03-24-2023)
Old 03-24-2023, 01:56 PM   #6
KillerBMotorsport
What is the benefit of that?
Old 03-24-2023, 01:57 PM   #7
KillerBMotorsport
That's good to hear.
Old 03-24-2023, 03:03 PM   #8
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
The second gen diffs seem to overheat more quickly than first gen diffs, no surprise with the extra power.
More tunable than the stock Torsen, you don't have to worry about tuning suspension setup around inside rear wheel lift.
DocWalt is offline
The Following 2 Users Say Thank You to DocWalt For This Useful Post:
KillerBMotorsport (03-25-2023), whataboutbob (03-24-2023)
Old 03-24-2023, 03:29 PM   #9
Lelandjt
Drives: '04 STi, '12 Mazda 3 Hatch
I'm interested in putting taller gearing in my diff (I assume you went the other way) so any info you can give me to track down parts would be useful.
Lelandjt is offline
Old 03-24-2023, 04:01 PM   #10
zeroomega
zeroomega's Avatar
Drives: Supra MKV, FR-S
Gen1 diff rarely fail, even among track folks. It is a torsen unit, which is robust and mostly worry free. People who upgrade the diff are mostly for changing into clutch type LSD for tunability and better locking behaviors (this type of differentials are actually need more attention and are less robust than the torsen) . IIRC the torsen on gen1 (and probably gen2) has a fixed 1:4 bias ratio and it cannot be changed. If one rear wheel lost contact with the ground (which is common with larger swaybar or higher spring rate coilovers), the torsen LSD effectively becomes an open diff.
zeroomega is offline
The Following 4 Users Say Thank You to zeroomega For This Useful Post:
alex87f (03-24-2023), KillerBMotorsport (03-25-2023), Stonehorsw (03-26-2023), whataboutbob (03-24-2023)
Old 03-24-2023, 05:29 PM   #11
vindiesel
vindiesel's Avatar
Drives: 2023 brz limited 6mt red
Clutch kicks/dumps per mileage ratio durability. Who’s tracking?
2023 brz red limited 6mt 10k miles ish
2009 Chrysler 5.7l hemi eagle 300c heritage edition 205k miles
vindiesel is offline
Old 03-24-2023, 05:45 PM   #12
whataboutbob
AutoX-10/10ths every run
Among many other things, the ability to effectively get on throttle earlier on corner exit.
Build thread:Here
whataboutbob is offline
The Following User Says Thank You to whataboutbob For This Useful Post:
Old 03-24-2023, 06:26 PM   #13
OkieSnuffBox
Drives: '23 BRZ Limited
Diffs in general tend to be pretty robust, even with high HP as long as you aren't doing clutch dumps or what can happen on track sometimes where on corner exit you're on throttle and drop a rear wheel off the tarmac. It's the shock loads that tend to really hurt stuff.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
OkieSnuffBox is offline
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
Old 03-24-2023, 09:31 PM   #14
Pat
Pat's Avatar
Drives: 2023 BRZ
The differential on my 2014 BRZ wore out after about 130,000 mi. It wasn't exactly kaput, but I could feel a difference with the car up in the air between the original diff and one in very good condition. It also had about 130 track days on it with fluid changes maybe every 20,000 miles.
Pat is offline
The Following 5 Users Say Thank You to Pat For This Useful Post:
DarkSunrise (03-24-2023), KillerBMotorsport (03-25-2023), timurrrr (03-25-2023), villainous_frx (03-28-2023), vindiesel (03-25-2023)
17+ MT Rear Diff Assembly 4.3 FD 86TOYO2k17 Want-To-Buy Requests 2 05-10-2020 03:04 PM
Which is better? Reaplcing rear diff bushings? or installing rear diff brace? Frs30 Engine, Exhaust, Transmission 22 04-13-2020 11:23 AM
17+ 4.3 Rear Diff ka-t_240 Want-To-Buy Requests 1 04-11-2018 10:24 AM
wtb rear diff APEXIT53 Want-To-Buy Requests 0 04-11-2016 12:15 PM
Rear diff service JoeBoxer Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 11-06-2012 11:23 PM
