Old 03-14-2023, 12:52 AM   #15
gkanga
Drives: 2014 FRS
Originally Posted by Grady View Post
Prying apart or forcing it together is not a good solution with a transmission. When you get the transmission loose the nose of the engine will dip down. Support the front of the engine. Take a look at everything else you may be missing something.
Pretty much every guide and instructional video I've seen says to use a prying tool to push the transmission back. I don't know how I would get it off without prying.
I am supporting the front of the engine with a floor jack. I've tried numerous small adjustments of the angle by lowering and raising the jack slightly.
gkanga is offline   Reply With Quote
Old 03-14-2023, 01:03 AM   #16
gkanga
Drives: 2014 FRS
I got them a little farther apart. I took this picture showing the shaft completely out of the clutch disc. It's currently in a little farther than this (engaged but probably just barely) after various attempts to remove it.
Once the shaft and clutch disc are separated the only things that should still be in contact are the two studs in the bottom, right? The two alignment pins are completely out. The studs don't seem like they're binding. I can push the transmission around up down left right and it moves freely through a small range of motion. It will move slightly back and return slightly forward when I let go. When I try to push it backwards with a pry bar on the bottom, the back of the transmission just tilts up until it hits the underside of the car.
It seems like either something isn't lined up exactly perfectly (I don't know how perfect it needs to be), and maybe once it's aligned to within a microradian it will come off. Or maybe the pilot bearing came out of the flywheel and it's stuck on the transmission shaft?? That seems unlikely.
Old 03-14-2023, 09:19 AM   #17
Ruben_86_
Ruben_86_'s Avatar
Drives: Toyota GT86
Sounds stupid, but has the wiring of the gearbox dropped?
Ruben_86_ is offline   Reply With Quote
Old 03-14-2023, 09:27 AM   #18
Tokay444
Have you disconnected the drive shaft?
The Following User Says Thank You to Tokay444 For This Useful Post:
Opie (03-14-2023)
Old 03-14-2023, 10:32 AM   #19
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Good catch...looks to me like all the starter wiring has not been taken loose...if the splines are that far out, it's not binding there...is the shifter disconnected? Drive shaft? all wiring?
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 03-14-2023, 12:04 PM   #20
gkanga
Drives: 2014 FRS
I finally got it out last night! I'll post more details when I get home from work this evening. Short version... The bracket that the transmission is pinned to at the top near the shifter was stuck hard and wouldn't budge even with the pins removed. It required major persuasion to dislodge, but once I did I had the transmission out within a few minutes.
The Following 2 Users Say Thank You to gkanga For This Useful Post:
blsfrs (03-14-2023), Ultramaroon (03-14-2023)
Old 03-14-2023, 04:24 PM   #21
gnarjunkie
Drives: '23 GR86, '17 BRZ
Oh yeah... that bracket got in my way too. We'd disconnected it fine but it got pinned between the body and the trans and was preventing us from sliding the trans out fully. It was pretty much impossible to see too, only noticed it by feeling around.
gnarjunkie is offline   Reply With Quote
Transmission removal 86league Engine, Exhaust, Transmission 7 12-10-2018 04:38 PM
Front seat removal woes, things I dealt with and you shoould be aware of.. OICU812 Cosmetic Modification (Interior/Exterior/Lighting) 11 04-01-2016 10:59 AM
Turbo Woes RedFR-s Forced Induction 38 10-14-2015 08:25 AM
Transmission selector shaft removal Nigelr32 DIY (Do-It-Yourself) Guides 0 12-29-2014 05:34 AM
More Woes for GM? White64Goat Other Vehicles & General Automotive Discussions 3 03-28-2014 11:23 PM
