Old 03-05-2023, 03:01 PM   #1
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
Non-Coilover option for racecar
Hi all,
My race team has a 2013 FRS we are running and we currently have rebound/height adjustable MCS Coilovers. One of the series we run (ChampCar) does penalty points based on mods, and these coilovers score us a ton of points and penalty laps.
We are looking for a sort of cup kit alternative that would save us the points for when we run Champ. I don’t see any full kits, so am mostly wondering if anyone here has experience with different shock/spring combos on track.
Thanks!
Flat Black VW is offline   Reply With Quote
Old 03-05-2023, 03:46 PM   #2
whataboutbob
AutoX-10/10ths every run
I'd start here: https://www.ft86club.com/forums/showthread.php?t=45554
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
Racecomp Engineering (03-05-2023)
Old 03-05-2023, 04:20 PM   #3
Bilstein B6 + RCE Yellow is one option.
Zdan uses B6 + Swift Spec R springs.
Are you allowed to run camber plates?
- Andrew
Racecomp Engineering is online now   Reply With Quote
Old 03-05-2023, 05:14 PM   #4
Flat Black VW
- Andrew
Thanks!
We are, and we do. They are 20 pts per pair, 10 points=1 penalty lap per 8 hours of racing.
The MCS coils were getting us 140 points total, a spring/shock combo would be at most 20 points total.
Rules on spring replacement:
“Suspension Springs, non-OE coil springs are 5-points per corner
- Exemption: Vehicles may replace OE coil springs for 0-points provided that the replacement spring:
▪ Is the same shape as the OE spring (straight, frustum, beehive/keg, etc.).
▪ Maintains the exact same ID/OD measurements as the OE spring (+/- 0.25”) when measured at the midpoint and at each end of the spring
▪ Springs may be cut and/or used with spacers (spring rubbers) for no additional points
▪ Shape and measurements must match when the springs are in their original
unaltered condition”
Not sure if any of your suggested meet the exemption reqs.
Old 03-05-2023, 08:49 PM   #5
jflogerzi
jflogerzi's Avatar
I ran OEM 2017+ dampers with peddlers top hats non adjustable and RCE yellows on track. Pretty solid combo. Add camber bolts for more camber if wanted/needed
Sent from my Pixel 6 using Tapatalk
2013 Series 10 FRS #553
Old 03-06-2023, 10:03 AM   #6
Originally Posted by Flat Black VW View Post
Thanks!
Our RCE Yellows or Swift Spec Rs should fit that criteria. Those are the only 2 springs I'd consider really for your uses at least.
And yeah, the OEM PP dampers do work well too if you have a set laying around or can find a low mileage set for cheap, but the Bilsteins are better and can take more heat.
- Andrew
Teseo (03-06-2023)
Old 03-06-2023, 10:54 AM   #7
meWant
Drives: '16 BRZ Limited
Depending on how soon you need the springs, I may have a set of RCE Yellows coming off my car hopefully within the next month or so
meWant is offline   Reply With Quote
Old 03-06-2023, 02:04 PM   #8
marco_mc22
Drives: Toyota 86
I still love my Oem 2017 Base dampers, how many points for sway bars and camber plates? IMO those dampers with a decent camber and a big front bar work really well plus they’ll be easy on tires.
marco_mc22 is offline   Reply With Quote
Old 03-06-2023, 02:09 PM   #9
norcalpb
norcalpb's Avatar
The stiffest springs for our cars I believe are the RCE Tarmacs (my springs by discontinued), but unfortunately no springs that go over 300 pounds.
Old 03-11-2023, 05:13 PM   #10
G-Man
G-Man's Avatar
Drives: 1980 corvette, 2014 Subaru BRZ
depending on how much money you want to spend I think you can put stock spring mounts on the MCS you have. not sure if that is still legal in your class, but it works for SCCA SOLO.
https://vorshlag-store.com/collectio...brz-scion-fr-s
G-Man is offline   Reply With Quote
The Following User Says Thank You to G-Man For This Useful Post:
strat61caster (03-11-2023)
Full racecar zberz Other Vehicles & General Automotive Discussions 9 05-05-2019 07:47 PM
Best Coilover Option for max low driving adamg Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 11-18-2014 02:39 PM
Non-Coilover Option? djliquidsteele Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 04-20-2013 08:57 PM
Found a new coilover option from Tein JoeBoxer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 02-23-2013 12:17 AM
KSport Coilovers - Another Coilover Option FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 08-15-2012 03:38 PM
