Old 02-10-2023, 09:06 PM   #1
Mings
Drives: 2017 Toyota 86
Exclamation Help - Broken Shifter or Bad Synchros?
After a very cold day in CO my shifter moves left and right freely in any gear as if it was neutral.
I'm being told I likely have bad synchros but I'm thinking (Hoping) it's just the shifter itself (bad bushing maybe?).
please send me your wisdom
2017 Toyota 86
Mings is offline   Reply With Quote
The Following User Says Thank You to Mings For This Useful Post:
humfrz (02-11-2023)
Old 02-11-2023, 12:03 AM   #2
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Just confirming. It was working fine, then a cold day happened, and now you have this problem. No missed shifts, no money shifts, noone else drove the car?
Do you know if there has been any work done on the drivetrain since the car left the factory?
Is the car driveable? Does the car still go into gear? Is it the right gear?
Any sounds coming from the transmission when you shift with the car off? With the car on if it runs?
My first thought is something went wrong with a shifter bushing somewhere, but more information will help track it down.
Ps assuming this is a manual lol
Also: "Build Thread"
Old 02-11-2023, 03:33 AM   #3
2017 Toyota 86
I had a floor shifter like that one time, but it was on my 1937 chev pickup.
I have no idea, however, I'll refer you to our shifter specialist, @Ultramaroon.
If you have busted something - there is a good chance he has busted the same thing and has some insight.
Ultramaroon (02-11-2023)
Old 02-11-2023, 02:29 PM   #4
Mings
yes there was no prior indicators, no one else has driven
unsure
i drove it a few miles like this, still went into gear, and it stayed in the right gear
no sounds
yes lol
x808drifter (02-12-2023)
Old 02-11-2023, 02:30 PM   #5
Mings
Old 02-11-2023, 03:13 PM   #6
Spuds
The Dictater
Spuds's Avatar
yes lol
Based on your info, my guess is the rear shifter mount bushing is broken. If it was a problem in the transmission, you probably wouldn't be able to get it into the right gear and you'd hear some pretty bad noises when driving.
The rear shifter mount is under the car just behind where the shifter passes into the tunnel. The cold might have caused the rubber bushing to get brittle and crack/snap which would allow more sideways motion of the shifter than usual, but would still fulfill it's basic function.
The Following 4 Users Say Thank You to Spuds For This Useful Post:
humfrz (02-11-2023), Ohio Enthusiast (02-11-2023), Ultramaroon (02-11-2023), x808drifter (02-12-2023)
Old 02-11-2023, 04:03 PM   #7
Mings
thanks, you're the man. I will post a conclusion when this gets replaced for anybody else having this issue
The Following 2 Users Say Thank You to Mings For This Useful Post:
humfrz (02-11-2023), x808drifter (02-12-2023)
Old 02-11-2023, 06:20 PM   #8
What? That's crazy talk.
Spuds (02-11-2023)
Old 02-11-2023, 09:34 PM   #9
Spuds
The Dictater
Spuds's Avatar
Phew! For a minute I thought I had gone sane!
The Following User Says Thank You to Spuds For This Useful Post:
help!, issue, shifter bushing, synchro, synchros
Kartboy short shifter broken spring magicchef Engine, Exhaust, Transmission 1 01-24-2018 03:41 AM
Synchros going bad? Terruko Issues | Warranty | Recalls / TSB 59 08-01-2017 10:45 PM
Synchros problem? FRiSson Issues | Warranty | Recalls / TSB 191 06-21-2016 05:27 PM
Are My Synchros Going Out? Scavanger Scion FR-S / Toyota 86 GT86 General Forum 11 11-20-2014 01:29 AM
Synchros followup FRiSson Scion FR-S / Toyota 86 GT86 General Forum 7 08-31-2012 03:38 PM
