Old 02-07-2023, 11:21 PM   #1
TheLemperor
P0018 P0019 P0021 after OFT tune back to stock
My car was on a stage 2 e85 tune and got rodknock. After getting the engine rebuilt at a shop and driving it until empty, I switched the tune back to the car's original tune to get it smogged. There were no check engine lights with the e85 tune, but now it has P0018 and P0019. P0021 also showed up before but after clearing it, it's not there right now. Any help is appreciated
TheLemperor is offline   Reply With Quote
Old 02-08-2023, 05:47 AM   #2
AussieBRZ
AussieBRZ's Avatar
Drives: WRB BRZ
The OFT tunes use a euro rom as a base
When you tune back to stock you go back to the USA based rom and they seem more sensitive to those cam codes
Also you might be going back to an older base rom again more sensitive to those codes
Not sure if can pass smog on a oft stage 1 petrol tune might help
AussieBRZ is offline   Reply With Quote
Old 02-08-2023, 11:26 PM   #3
TheLemperor
Thanks for letting me know
Old 02-08-2023, 11:30 PM   #4
TheLemperor
Do you think I can pass smog using a euro oem tune?
Old 02-09-2023, 04:27 AM   #5
tomm.brz
Drives: brz 2017 hksv2
difficult to say, you need someone Expert in how the smog check works in California, i think they also Connect to obd and check for "things" our euro cars with euro calibration don t necessarily count for
in italy they only check exhaust gas with their sensor, so i regularly tune people also with aftermarket without cat Headers, and the stock oem front pipe installed and they pass it if they show up there with a warmed up car
but California is rinomated for stringent controls
Old 02-09-2023, 06:32 AM   #6
AussieBRZ
AussieBRZ's Avatar
Drives: WRB BRZ
As Tom said hard to say if you can pass on a euro tune
If you're in California no chance as they check the ECU claid and the checksum verification number so you need stock tune car was supplied with
Other states might be possible depends on strictness of tests
Rebuilt engine cam issue (P0019/P0021) hu60 Issues | Warranty | Recalls / TSB 15 02-01-2023 04:14 PM
Codes P0011, P0016, P0018, P0021 SamCon7 Issues | Warranty | Recalls / TSB 5 05-31-2021 06:06 AM
Back to stock tune from Ecutek BP_FRS_26 Software Tuning 1 03-12-2021 10:13 PM
Taking car back to stock - can I use the upgraded MAP sensor with stock ECU tune? Foobar Software Tuning 17 07-01-2019 11:26 AM
Tuner ecutek tune back to stock? Toyota John Software Tuning 16 04-27-2016 08:08 PM
