Old 01-12-2023, 10:05 PM   #1
traffic335
Lug Clearance - Issue
I just got a set of 18x9.5 Motegi wheels on an outstanding deal in order to work on fitment which will allow me to order a better set of forged wheels in the future.
Upon installing them I was pretty amazed about the lack of socket clearance to tighten down a lug nut. I am wondering what the best way to remedy this is before I have the wheels machined. As it stands, I can not tighten the wheels with a socket.
Thinking out loud, maybe I can run a longer stud and a much deeper lug to be able to keep a socket with enough engagement to turn the lug?
traffic335 is offline   Reply With Quote
Old 01-12-2023, 10:49 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Look up "Tuner lugs". Useful for aftermarket wheels that have little room. Most auto stores have them in stock
I also have Motegi (MR116) as winter wheels and have to use "tuner lugs"
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
traffic335 (01-12-2023), x808drifter (01-13-2023)
Old 01-12-2023, 11:13 PM   #3
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Spline drive lug nuts require an adapter, but often run much narrower than standard hex lug nuts
You can also look into internally keyed lug nuts where the tool fits on the inside (rather than over the outside), like Project Kics Monolith
EndlessAzure is offline   Reply With Quote
The Following 3 Users Say Thank You to EndlessAzure For This Useful Post:
Grady (01-19-2023), traffic335 (01-12-2023), x808drifter (01-13-2023)
Old 01-13-2023, 06:18 PM   #4
Tatsu333
Drives: 2020 BRZ Sport Tech RS
Yup - SplineDrives (or other "tuner" lug nuts) are the way to go. Stock lug nuts (or anything with a similar outer size) are too big for a lot of aftermarket wheels. SplineDrives have TONS of room on my wheels.
Tatsu333 is offline   Reply With Quote
The Following User Says Thank You to Tatsu333 For This Useful Post:
Grady (01-19-2023)
Old 01-19-2023, 07:04 PM   #5
Grady
Grady's Avatar
3X spline nuts.
Valve clearance adjustment issue bobel Engine, Exhaust, Transmission 35 02-29-2020 03:52 PM
3" Overpipe Clearance issue Zee2413 Engine, Exhaust, Transmission 16 08-20-2017 12:19 AM
Perrin P.S.R.S. clearance issue 15limited Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 05-11-2017 11:05 AM
Short shifter clearance issue with driveshaft Gank61 Engine, Exhaust, Transmission 16 03-08-2016 07:48 AM
Clearance issue Wilson15 Engine, Exhaust, Transmission 0 10-17-2014 03:52 PM
