Old 11-27-2022, 11:13 PM   #15
Pat
Pat's Avatar
Drives: 2023 BRZ
Originally Posted by Apelsin View Post
You too man by your own logic. But don’t you find it ironic for all the talk about how coaching is superior to modifications, 95% of track day guys spend thousands on mods and zero on coaching.
And the other 5% go faster with slower cars.
The Following 7 Users Say Thank You to Pat For This Useful Post:
Desertnate (11-29-2022), Jdmjunkie (11-28-2022), Krokodil (11-30-2022), Ohio Enthusiast (11-28-2022), RToyo86 (11-28-2022), Tokay444 (11-30-2022), TommyW (11-28-2022)
Old 11-28-2022, 11:52 AM   #16
TommyW
TommyW's Avatar
Drives: '13 Whiteout
yep. I’ve had some great coaches including CSG Mike and coaching is BY FAR the best thing you can spend money on to improve as a driver.
Driver improvement>car improvement.
TommyW is offline   Reply With Quote
Old 11-28-2022, 12:54 PM   #17
ZDan
ZDan's Avatar
Drives: '23 BRZ
Still, you don't have to be a great driver to benefit greatly from knowing which mods are going to be most effective and practical for track usage. If anything you'll get more from coaching if your car is decently well setup vs stock. I don't really get all the "driver mod >>> car mod" comments...
Also worth mentioning that a LOT of the most readily-available instruction/coaching isn't all that great and can often be counter-productive... In my early driving "career" I got next to nothing out of the piss-poor "instruction" and coaching I got. At a BMW driver school at Mont Tremblant all my "instructor" could offer was "you're going too fast!" and "you don't know how fast you're going!" as we entered Turn 1 at perfectly reasonable speeds. Lotsa (internal) laughs...
The Following 3 Users Say Thank You to ZDan For This Useful Post:
Krokodil (11-30-2022), therealstoly (11-28-2022), timurrrr (11-29-2022)
Old 11-28-2022, 01:08 PM   #18
TommyW
TommyW's Avatar
esdzx
Well, it means learning weight management, etc is better than adding mods, especially sticky tires too soon. People are too quick to put on sticky tires. Low grip tires and you'll learn faster.
Good coaching comes from selecting the right ones.
Old 11-28-2022, 02:43 PM   #19
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by TommyW View Post
esdzx Well, it means learning weight management, etc is better than adding mods, especially sticky tires too soon. People are too quick to put on sticky tires. Low grip tires and you'll learn faster.
Alas, this is another one I disagree with! I would much rather my students arrive in a decently trackworthy setup and on track-appropriate tires that can stand up to abuse and provide decent sliding grip. IMO this *improves* the learning curve relative to punishing not-up-to-trackdays tires with softish stock near-zero camber setup, which often begins to feel like a waste of time.
Unfortunately the right ones are not likely to be readily available at the vast majority of track-day events.
The Following 2 Users Say Thank You to ZDan For This Useful Post:
Old 11-28-2022, 02:52 PM   #20
TommyW
TommyW's Avatar
It depends on experience. New drivers don't need mods if the car is already track capable beyond pads and fluid.(Miata, BRZ, Corvette, etc).
As far as coaching, it's best to seek someone out beforehand.
Old 11-28-2022, 04:42 PM   #21
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
Add a lot of seat time
The Following User Says Thank You to gen3v8 For This Useful Post:
whataboutbob (11-28-2022)
Old 11-28-2022, 07:06 PM   #22
CSG Mike
CSG Mike's Avatar
Those are the ones who don't need coaching as badly as the clueless ones!
And you're 100% right. There are volunteer/"i want a cheap/free track day" coaches, and professional coaches.
Old 11-29-2022, 01:29 AM   #23
Apelsin
Drives: Jeep
You're still asking essentially the same questions 3 years later. How much have you improved in those 3 years?
Isn't it interesting that the same questions illicit the same answers from me? Perhaps, there may be a reason.
If you;re looking for confirmation bias, this is likely the wrong place. If you want real answers.... well, you got them. You don't have to like them, because it's not an easy pill to swallow, but perhaps, you should try looking from a different perspective.
I don’t know. I didn’t mean to ask the same question. I’m sorry if I did. I was really looking for someone to share their numbers. Something along the lines my lap times dropped 3 seconds when I upgraded my suspension.
Apelsin is offline   Reply With Quote
Old 11-29-2022, 01:41 AM   #24
Apelsin
Drives: Jeep
Anyways I found ZDan’s answer pretty helpful for what I was looking for.
The Following User Says Thank You to Apelsin For This Useful Post:
ZDan (11-29-2022)
Old 11-29-2022, 02:12 PM   #25
CSG Mike
CSG Mike's Avatar
A does not result in B, with cars.
Old 11-29-2022, 09:01 PM   #26
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
All other things being equal, coilovers/springs/dampers don't affect peak lap times as much as some people think.
I've seen a lot of examples when good drivers on stock suspension and 225 SX2s were on average just 0.5–1.0s per lap slower than similarly good drivers on coilovers and 245 SX2s.
That being said, a well set up suspension can be more predictable and can provide the driver with more confidence to drive fast lap after lap.
On the flip side, a well set up suspension might have such a balance that an inexperienced driver will spin in their first session.
Note that I said "all other things being equal", I want to stress that it includes camber.
There's a night-and-day difference in grip between factory and proper track alignment.
You may find https://86cup.us/calculator/ interesting.
Coilovers are 2pts there.
I don't know how much lap time differenced does 1 pt translate to, but eyeballing their records, and assuming Stock is -1pt and all Street records were set with 4pt builds, 1pt is ~0.5–1.0s per lap?
Follow the build thread for my GR86!
The Following 5 Users Say Thank You to timurrrr For This Useful Post:
Apelsin (11-29-2022), J95 (01-10-2023), NoHaveMSG (11-29-2022), Ohio Enthusiast (11-29-2022), StraightOuttaCanadaEh (11-30-2022)
Old 11-29-2022, 10:51 PM   #27
Apelsin
Drives: Jeep
That was very interesting timurrr. Thanks for sharing! Seems like you came up with a great rule of thumb to translate mods into lap time improvements
Old 11-30-2022, 09:49 AM   #28
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Are you using any data acquisition? Garmin? Aim?
Santa is supposed to bring me a Garmin for Christmas.
6 speed manual and speed levels DaPistonHead BRZ First-Gen (2012+) — General Topics 57 05-12-2020 02:41 PM
2016 FR-S 6-speed/only 14,500 miles/quality mods/ATL,GA cbryant514 Cars for Sale/Trade 4 08-26-2018 05:33 PM
I'd rather corner. Hoahao Other Vehicles & General Automotive Discussions 11 08-10-2015 03:17 PM
top speed axleback....or top speed dual catback? pepe Engine, Exhaust, Transmission 10 11-07-2014 08:12 PM
Need for Speed Movie Meet at Tysons Corner 3/14 (Late Night Showing) kanundrum Mid-Atlantic 48 03-15-2014 09:40 PM
