Old 10-15-2022, 03:26 PM   #15
JBezugs
Good Job Subaru!
JBezugs's Avatar
Drives: '18 440i GC, '24 CX-50 Meridian
Ended up throwing the OEM catback back on, much better. Still has a surprising amount of volume outside the car, but no more drone in the car! Great success!
JBezugs is offline   Reply With Quote
Old 10-22-2022, 03:57 PM   #16
Thefalls
Thefalls's Avatar
Drives: Corolla GT
Indeed stock everything after the header is "droneless".
I went with a resonated/catted (cat is from an STI,supposed to high flow) Front pipe and JDM quad exhaust.
Note that i wrapped the front pipe as i didn't like the heat radiating from it into the cabin during the summer days.
And changed all hangers (5 of them).
It was all done in increments.LOL.
First was header (EL and wrapped) then front pipe followed by wrapping FP then quad exhaust and finally hangers.
In this way i was able to experience the changes and was genuinely surprised by the effect of the hangers.
There was some drone after i added the TRD quad exhaust, around the 2-2.5k rpm when cruising and then I fitted the hangers.
And the drone disappeared, almost.
The reverberations from the exhaust into the cabin also disappeared. (read as less boomy)
And no it was not a psychological change.
Thefalls is offline   Reply With Quote
Old 10-22-2022, 04:40 PM   #17
JD001
JD001's Avatar
Drives: Subaru BRZ
I kept everything standard OEM from the mid-pipe to the back.. Fruity when pushed otherwise it's pretty quiet.
Old 10-23-2022, 01:13 PM   #18
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
JDL header thread is hovering around this one but figured I'd link to my post for anyone curious. I have little to no rasp with this setup. And essentially zero drone. Slightly boomy on startup but otherwise very tame.
I ran a punched out OEM header with this same setup and noticed more drone to the point I couldn't drive with the windows down without headaches and ear pain.
https://www.ft86club.com/forums/show...&postcount=445
Will header cause rasp? Tysoncrosby21 Engine, Exhaust, Transmission 8 02-12-2017 04:09 AM
headers rasp mamamiaellis Engine, Exhaust, Transmission 13 05-20-2015 10:20 PM
Rasp issue, need help on fix? slyder Engine, Exhaust, Transmission 9 01-23-2015 05:09 PM
Glasspack to get rid of rasp? dem00n Other Vehicles & General Automotive Discussions 3 10-18-2014 09:56 AM
Rasp help??? Gshoxx Engine, Exhaust, Transmission 3 05-01-2014 01:20 AM
