Old 10-15-2022, 12:43 AM   #1
turbowhistle
Exclamation Tail Fuse keeps blowing
My taillight DRL and plate light randomly stopped working. The 10a Fuse (#4 TAIL) keeps blowing. The brake lights and turn signals still work. I've tried unplugging the tail lights,4th brake, plate lights, and headlights but the fuse is still blowing. The DRL works for a split second and then the fuse pops. I checked for any damaged wiring or loose grounds in the trunk area but I cant find anything. I'm having a hard time finding the short and was wondering if you guys experienced the same or can point me in a better direction.
I was also wondering if I can bypass the #4 Tail fuse by splicing the DRL wire to some other constant 12v wire so that I can at least be able to drive the car at night.
Any help is appreciated!
I have Valenti 60-1412 tail lights with the matching 4th brake light.
Side note I don't have the front side markers plugged in, not sure if that's tied to Fuse #4
turbowhistle is offline   Reply With Quote
Old 10-15-2022, 09:21 AM   #2
The Red One
Pro Couch surfer
The Red One's Avatar
Drives: 2019 BRZ Sport-tech RS.City car:GD3
Cant help you much,will leave some others reply,
but here is some good reading to help you troubleshoot.
https://www.ft86club.com/files/BRZwiringi.pdf
The Red One is offline   Reply With Quote
Old 10-15-2022, 04:42 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
If you've unplugged all the light housing harnesses that are controlled by that fuse, that would mean there's a shorted wire somewhere else in the vehicle. I would start wherever mods were added, something likely got pinched.
Old 10-16-2022, 04:05 AM   #4
turbowhistle
That seems to be it. Do you think it would be possible to directly wire the drl to something like the turn signal, bypassing the fuse#4?
Old 10-16-2022, 11:21 AM   #5
soundman98
soundman98's Avatar
i wouldn't bypass any fuse. the fuse blowing is telling you something is seriously wrong.
x808drifter (10-16-2022)
Old 10-16-2022, 11:31 AM   #6
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Fk it.
Car fire for warmth.
Old 10-16-2022, 11:39 AM   #7
soundman98
soundman98's Avatar
just stick a wire in the fuse and let it burn.
The Following 4 Users Say Thank You to soundman98 For This Useful Post:
Decep (10-16-2022), jcw99 (10-18-2022), Tcoat (10-16-2022), x808drifter (10-17-2022)
BRZ TAIL FUSE BLOWING 404dare Cosmetic Modification (Interior/Exterior/Lighting) 14 04-13-2023 09:25 PM
Tail light fuse keeps blowing Natasha BRZ First-Gen (2012+) — General Topics 6 07-05-2022 07:33 PM
Fuse #4 Taillights Keeps Blowing epplecc Electronics | Audio | NAV | Infotainment 1 07-08-2021 07:12 PM
Tail/Fog/Plate light fuse keeps blowing leevanf BRZ First-Gen (2012+) — General Topics 5 09-07-2018 09:09 PM
Running light "Tail" fuse in foot well keeps blowing **Fixed** paintdude258 Electronics | Audio | NAV | Infotainment 0 04-12-2017 04:59 PM
