Old 09-26-2022, 01:43 PM   #1
Ashphalt_Angel
Drives: Truck
Trans rebuild OEM
Doing some searching online and not finding too much on rebuilding the transmission on these cars. My 5th and 6th gear grind above 4K Rpm. I mostly drive highways so I don't spend a terribly long amount of time shifting in these gears but it is annoying when I need to pass someone.
Is everyone just replacing transmissions when/if this happens? Car has a little over 130k on it.
Ashphalt_Angel is offline   Reply With Quote
Old 09-26-2022, 02:13 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
When is the last time you changed the transmission fluid and what are you running for fluid? Good fluid makes a huge difference.
Used transmissions are 4-600 so people don't really rebuild them, problem is you don't know what you are going to get used. I would call a local transmission place for a quote, snycro's maybe toast, they are a bit sensitive in these.
DarkPira7e (09-27-2022)
Engine rebuild Locost7 Engine, Exhaust, Transmission 2 09-14-2020 01:50 PM
Can RSR coilovers be rebuild? ysr50guy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 08-19-2017 01:34 PM
'13 Subaru BRZ rebuild P3tras Member's Car Journals 96 01-03-2016 07:05 PM
Looking to rebuild a Scion FRS miller.4311 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 4 06-24-2015 07:47 PM
fs: Perrin trans mount and whiteline trans bushing RWD_FR-S Transmission and Driveline 1 01-02-2014 06:34 PM
