Old 09-25-2022, 07:48 PM   #1
Nintain
Drives: 2015 Scion FR-S A/T
New engine start up
I was finally able to get my engine assembled however for whatever reason it won't turn over but it sounds like it wants to. The battery is a year old, fuel is primed, with old coil packs, and brand new dealer spark plugs. I'm going to eventually get a mechanic to come and and look at it but I was wondering if any of you had an idea by the sound of it or what I could test.
Nintain is offline   Reply With Quote
Old 09-25-2022, 09:21 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Too short of a video to know what's up. Post a video of it turning over for 5-10 seconds so we can hear what the timing sounds like.
Hold your foot down on the gas pedal when cranking, it won't send fuel and so it won't start
Old 09-25-2022, 09:56 PM   #3
Nintain
This is pretty much how it sounds now but this video here was before I discovered two port injections had destroyed o rings and was leaking fuel which have been replaced. The first video is what it sounded like after I replaced them so idk if this video helps.
Old 09-25-2022, 09:59 PM   #4
Nintain
I've also been holding my foot down while cranking.
engine startup, hard start, issues
FS: STI engine start push start OEM plug and play sokol Interior Parts (Incl. Lighting) 5 06-13-2019 03:12 PM
Engine won't start after rebuild septonb Engine, Exhaust, Transmission 7 05-26-2017 11:48 PM
engine won't start after pushing it andrew5826 Engine, Exhaust, Transmission 9 09-01-2016 11:34 PM
Engine doesn't start right away Cajun Issues | Warranty | Recalls / TSB 1 02-04-2013 03:09 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 04:44 AM
