go_a_way1, MisterSheep
Old 09-07-2022, 02:03 PM   #23857
Kaotic Lazagna
Drives: GR Corolla
Originally Posted by Wally86 View Post
Which method did you use to do the plugs? (Motor lift, hand jam, fa delete)
I'll take hand jam for 800. LOL
I ended up removing the left strut tower brace cuz I couldn't get the fuel rail cover/thing off with it on.
I also removed the intake since I dropped the extension into the abyss. That didn't bother me too much since I was going to reinstall my Perrin intake tube anyway.
The Following 3 Users Say Thank You to Kaotic Lazagna For This Useful Post:
new2subaru (09-07-2022), RToyo86 (09-07-2022), Wally86 (09-07-2022)
Old 09-08-2022, 10:00 PM   #23858
orz
orz's Avatar
Drives: Halo
What's in the box?
Putting together a custom 2022 OEM+ GR86/brz Oil Cooler/Regulator kit. I got a sweet discount at a local Subaru dealer at San Bernando, CA so I put spent a lil extra on some nice hoses and adapters. The cooler lines measures 3/8" ID and the manifold measures 5/16" ID.
Oil Cooler Complete: 21311AA220
Oil Cooler Connector stem: 21317AA070
HPS Hose 3/8" ID (3ft)
HPS Hose (90deg) 5/16" ID
Reducer Adaptor 3/8"->5/16"
Subaru Coolant
x4 Worm Clamps ~16mm
x4 Spring Clamps ~16mm
Going to reschedule this install hopefully next week when it's not so hot outside.
orz is offline   Reply With Quote
The Following 3 Users Say Thank You to orz For This Useful Post:
Compelica (09-14-2022), MJones_RB (09-12-2022), Teseo (09-10-2022)
Old 09-10-2022, 01:13 AM   #23859
keenanok
keenanok's Avatar
Drives: 2013 Whiteout FR-S
Switched over to some Solo Werks S1 Coilovers from the BC’s with 40k swift springs, and the ride quality feels amazing! Also, what a wonder what a fresh wash and wax can do!
keenanok is offline   Reply With Quote
The Following 2 Users Say Thank You to keenanok For This Useful Post:
Tcoat (09-10-2022), Wally86 (09-12-2022)
Old 09-10-2022, 05:47 PM   #23860
Teseo
Drives: frs
Subaru Coolant
Those bended hose should make the install a breeze. I struggled with mine but was worth the effort. Oil temps doest spike
The Following 2 Users Say Thank You to Teseo For This Useful Post:
orz (09-10-2022), Wally86 (09-12-2022)
Old 09-14-2022, 05:28 AM   #23861
salotelsingha
Drives: RWE
I really wish it would stop raining. install vidmate get-mobdroapk.com
salotelsingha is offline   Reply With Quote
Old 09-14-2022, 12:22 PM   #23862
Compelica
Compelica's Avatar
Drives: 86 GT
Subaru Coolant
Nice! Any difference between the Forester and GR86 oil cooler units though?
Also, finally got around to servicing my coilovers - fresh oil, new dust boots and bump stops. And finally no more clunks, apparently from the worn spherical collar.
DIY stuff at Compelica Works
Compelica is offline   Reply With Quote
Old 09-14-2022, 02:24 PM   #23863
orz
orz's Avatar
Drives: Halo
Good question! Yes, there's a slight difference in the location of the coolant lines which makes hose management easier to work with the GR86 design. The Forrester measures somewhere around 3/8" ID and 1/2" ID. So you'll need a compatible hose and clamp that won't leak considering it will connect to the manifold lines at smaller ID.
Nice work on the rebuild. Fresh parts are always nice.
The Following User Says Thank You to orz For This Useful Post:
Old 09-21-2022, 08:41 PM   #23864
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Installed a TRD sandwich plate to put a defi oil pressure gauge in.
The Following 8 Users Say Thank You to DarkPira7e For This Useful Post:
jcw99 (09-23-2022), Kaotic Lazagna (09-22-2022), MJones_RB (09-27-2022), RToyo86 (09-23-2022), StraightOuttaCanadaEh (09-22-2022), Teseo (09-24-2022), villainous_frx (09-24-2022), Wally86 (09-27-2022)
Old 09-22-2022, 02:02 PM   #23865
Kaotic Lazagna
Drives: GR Corolla
Gave her a wash and got rid of the rust dust that got on the paint from parking right up against a chain link fence (ended up being super windy and rainy that day).
The Following 10 Users Say Thank You to Kaotic Lazagna For This Useful Post:
Clipdat (04-28-2023), DarkPira7e (09-22-2022), KMA KiCKz (09-23-2022), MJones_RB (09-27-2022), new2subaru (09-23-2022), NLSP (09-23-2022), RToyo86 (09-23-2022), Teseo (09-24-2022), Wally86 (09-27-2022), weederr33 (09-23-2022)
Old 09-22-2022, 02:37 PM   #23866
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
Everything I've read here indicates those units are not sufficient for track. Am I wrong about that?
Qwimby1 is offline   Reply With Quote
Old 09-23-2022, 10:30 AM   #23867
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Purchased Billetworz 500g shift knob from @vfrqqq. My butt dyno says it added 2.57 hp. Feels really nice too.
The Following 5 Users Say Thank You to blsfrs For This Useful Post:
DarkPira7e (09-23-2022), MJones_RB (09-27-2022), Teseo (09-24-2022), vfrqqq (09-23-2022), Wally86 (09-27-2022)
Old 09-23-2022, 03:47 PM   #23868
new2subaru
Weight Weenie
Drives: 15 FR-S
Went to the track.
I was all over the place and couldn't get it together. Couldn't focus. Left early..
Old 09-23-2022, 05:35 PM   #23869
KMA KiCKz
Certified Wumbologist
KMA KiCKz's Avatar
Drives: 2015 Scion FR-S
Gave it a good wash today
- My 2015 Scion FR-S OEM+ Build Thread -
TRD | Brembo | RAYS
KMA KiCKz is offline   Reply With Quote
The Following 6 Users Say Thank You to KMA KiCKz For This Useful Post:
Kaotic Lazagna (09-23-2022), MJones_RB (09-27-2022), NLSP (09-23-2022), Teseo (09-24-2022), villainous_frx (09-24-2022), Wally86 (09-27-2022)
Old 09-24-2022, 08:08 PM   #23870
SoCalHANZ86
HANZ
SoCalHANZ86's Avatar
Drives: 2014 frs
changed brake fluid.
SoCalHANZ86 is offline   Reply With Quote
The Following 2 Users Say Thank You to SoCalHANZ86 For This Useful Post:
bcj (09-25-2022), Wally86 (09-27-2022)
