| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Hey everyone! I’m kinda new here so it’s awesome to be on the forum. I had a quick question.
So recently I changed my clutch out on my 2013 Scion FR-S and of course changed the gear oil. I used Royal Blue. I know some people have said that it’s crap but I read that after I threw it into the car. I think I might have overfilled it because my car is running a bit sluggish. Is that maybe the new clutch getting broken in or is that a common issue with too much oil? When I plugged it the car was still weeping a steady stream of oil, but I couldn’t feel a pool of oil when my finger went in so I assumed it was below the line. I’m a bit confused. This is my second clutch job, the first being on a manual Jeep, so any advice would be appreciated. Also, my shifter falls into gear without needing the clutch. I’m assuming that means my clutch pedal needs adjusting, but any reassurance on that? ![]() Thanks a bunch Last edited by MaxwellSlides; 09-20-2022 at 11:16 PM. |
#2 |
Assuming the battery was disconnected, the ECU has to re-learn some parameters after having lost power. Give it a few cycles to sort out your throttle pedal and such.
You would have to try really hard to overfill the transmission. I'm sure it's fine. Clutch mechanism is self-adjusting. It's possible to improperly adjust the pedal throw but the worst outcome is a slipping clutch. Did you adjust the pedal?
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | NoHaveMSG (09-20-2022), x808drifter (09-21-2022) |
#3 | |
Any idea? I might just post in another forum bc I feel this is a deeper issue. |
#4 | |
Does the starter motor even click when it quits working? Ever try tapping it? Worn motor brushes show up as dead spots in the motor's arcs of rotation. For a while, tapping the motor can get them to make contact enough to start.
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | humfrz (09-20-2022), soundman98 (09-20-2022) |
#5 | |
#6 | |
![]() Fess up, Ultramaroon, you ARE related to Bubba -
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | soundman98 (09-20-2022), Ultramaroon (09-21-2022) |
#7 | |
I’m wondering, how to I test how much voltage is reaching the starter? Is it the little white wire going to the solenoid plus the ground, or the thick one next to that tiny one that’s bolted on + the ground? |
#8 |
ProCrastinationConsultant
check your clutch switch, they're prone for going out, and will cause a no-start condition as well.
if you're not getting any click at all out of the starter/relay, i don't believe the starter is the problem
| The Following 2 Users Say Thank You to soundman98 For This Useful Post: | NoHaveMSG (09-21-2022), Ultramaroon (09-21-2022) |
#9 |
Drives: Crapcan
Put a multimeter on the battery and check voltage while someone else cranks the car over and tell us what it reads.
#10 |
i bet it's 12.63v
| The Following User Says Thank You to soundman98 For This Useful Post: | NoHaveMSG (09-21-2022) |
#11 |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | soundman98 (09-21-2022) |
#12 |
The clutch switches tend to burn out with the keyless systems. With keyed ignition switches, one would have to be in the habit of letting go of the clutch before releasing the key to the "run" position. Nobody does that.
Get someone to (try to) crank the starter while you're testing voltage between chassis ground and the thin wire to the solenoid. If there's juice, everything inside the cabin is good. If not, it gets complicated.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | soundman98 (09-21-2022) |
#13 | |
Really appreciate the help with diagnostics btw. Y’all are awesome and hella funny lol |
#14 | |
Nobody has asked yet but is the car all stock? No headlight, taillight, HU etc swaps? The relay is #45 in the attached diagram. There are also a couple of fuses. #21 under hood and #14 under dash. If it is so intermittent it could be the relay. https://www.autogenius.info/scion-fr...e-box-diagram/
| Tags |
| #trannyfluid #newclutch |
| Anybody running Exedy stage 2 clutch? | 14BRZ | Engine, Exhaust, Transmission | 65 | 05-26-2020 01:21 AM |
| Car will not go into gear after new clutch install?! | Amartinez99 | Engine, Exhaust, Transmission | 15 | 01-15-2018 02:25 PM |
| Feels sluggish after clutch pedal adjustment | brianhj | Engine, Exhaust, Transmission | 6 | 08-24-2013 01:58 PM |
| frs sluggish in first and second gear at 2k-4k rpm | M&W_FRS | Issues | Warranty | Recalls / TSB | 3 | 06-23-2013 04:09 PM |
| Sluggish/Stalling After aFe Intake Install | FR-S Matt | Engine, Exhaust, Transmission | 6 | 01-15-2013 09:57 PM |
