Drives: GR86
Front tire damage in skidpad.
Falken 660 with 5-6 trackdays, 28 psi hot. This happened on a Streets of willow skid pad excersize. I was pushing pretty hard trying to figure out the limits of the car and the tires. Getting a lot of understeer off very tight 180 degree turns. Second gear full throttle coming out of the turn would just push instead of oversteer. I think the speeds were a bit too slow and the weight shift to the back would grip the rear. Dry conditions plus low tire pressures….not the right thing to do on the skid pad. Sheered the thread right off.
Just ordered GT Radial sx2s from Walmart, lets see how they hold up. https://imgur.com/a/UCdqDnF |
#2 |
Drives: Crapcan
They were starting to delaminate and you kept running them. You can see it starting here. 28psi hot is really low to me. I ran 34-37psi. 5-6 days is pretty good out of a set. I got like 4 days.
#3 | |
Drives: GR86
Edit:Also would more camber (in addition to higher pressures) help here? |
#4 | |
Drives: Crapcan
That is a spot we’re you almost wore through the tread and it then pealed a chunk away. Then continuing to run on the tire it caught a spot like that and pulled a chunk of the tread away. Need to check your tires before every session. Here’s a pic of one of mine.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | andyk5 (09-11-2022) |
#5 | |
Drives: GR86
#6 | |
Drives: Crapcan
Put new tires on, they are done at that point.
| The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post: |
#7 | |
Drives: '13 Whiteout
| The Following User Says Thank You to TommyW For This Useful Post: | Icecreamtruk (09-26-2022) |
#8 |
Drives: GR86
Yeah…I was “trying” to trail brake towards the tight apex and come out on the gas but did not get the result I was looking for. Next excersize was going around the white circles which would have been easier to break loose on but I did not make it that far. Tire shop was closed and the tire stores I called in the Lancaster area did not have anything decent in stock.
#9 | |
#10 |
Turn your steering wheel less, coming out of the turn.
You're causing your own push. |
| The Following 4 Users Say Thank You to CSG Mike For This Useful Post: |
#11 | |
Drives: GR86
Will try that next time. |
#12 |
Why would you be use RT 660's skid pad stuff anyways. Get some cheap tires like you ordered
2013 Series 10 FRS #553
#13 |
#14 | |
Drives: GR86
also they were close to being done. Now that I found out about 86Cup, I am going to try to compete in the Stock class, SX2s seem to be ok for stock, cheap and something I can learn on by getting as much track time as possible without breaking the bank as hard. |
| The Following User Says Thank You to andyk5 For This Useful Post: | CSG Mike (09-19-2022) |
| Front bumper damage is this repairable? | JaeMHC | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 11 | 09-05-2020 12:21 AM |
| tire damage question? | Thet | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 03-26-2015 03:07 PM |
| Front bumper damage | roosahorn | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 4 | 07-27-2014 02:46 AM |
| Little Front bumper damage | tintumz22 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 6 | 05-16-2013 02:47 AM |
| Damage to built up area of sidewall/stock tire. | Zadkiel | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 23 | 09-25-2012 09:03 PM |
