Old 09-06-2022, 01:37 PM   #1
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Check SRS Airbag System Light After Seat Cleaning
If you're like me, and likes to clean the seats at least once a year, or spill a drink on your passenger seat, and have encountered a "Check SRS Airbag System" light, here's the solution.
Absorb as much liquid as you can with a towel, open windows on a hot sunny day, and recirculate hot air inside the car to further prevent humidity issues.
Let it dry.
Any other humidity issues can be solved by placing a Damprid container inside the car.
Problem should go away. Else, disconnect the negative lead on battery, place foot on brake, re-connect lead, try again.
If you left the windows down during a rainstorm, or drove your car into the river, you'll have worse problems than worrying about your airbag system.
spcmafia is offline   Reply With Quote
The Following 2 Users Say Thank You to spcmafia For This Useful Post:
soundman98 (09-06-2022), x808drifter (09-07-2022)
Subaru BRZ 2018 "Check SRS Airbag System" bypass Adrhe BRZ First-Gen (2012+) — General Topics 3 02-19-2020 07:26 PM
Temp removal of pass seat (airbag light) mhiscott Cosmetic Modification (Interior/Exterior/Lighting) 7 08-30-2018 11:39 AM
BRZ / FRS Seat Swap - No Airbag Light! JohnPayneFun Cosmetic Modification (Interior/Exterior/Lighting) 3 07-23-2018 03:27 PM
WTB: Resistor for Aftermarket Seat Airbag Light KPDoubleX Canada Classifieds 9 05-01-2016 04:57 PM
Side Airbag light with aftermarket seat? Hanakuso Cosmetic Modification (Interior/Exterior/Lighting) 7 04-09-2014 04:20 PM
