| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#15 |
ProCrastinationConsultant
my corner stops are loose.
think my hood bent itself
#16 | |
I have known about this hood flapping effect since the very beginning and with all the meets I've attended, never thought to ask others in person. Do the hood and fender lines match? Mine do nicely. Is it possible that the front clip is high? I'm talking about the hardware that screws together over the radiator and such. Not sure if I'm using the right terms.
#17 |
Drives: Crapcan
I can’t see my hood while driving. Problem solved.
| The Following 5 Users Say Thank You to NoHaveMSG For This Useful Post: | sato (07-06-2025), soundman98 (08-21-2022), Ultramaroon (08-21-2022), villainous_frx (08-21-2022), x808drifter (08-22-2022) |
#18 | |
The Dictater
Drives: '13 Red Scion FRS
My eventual solution will be latches and/or vents, but I'm procrastinating to see how much I actually want to mod the frs lol. 9 years and counting... |
| The Following User Says Thank You to Spuds For This Useful Post: | Ultramaroon (08-21-2022) |
#19 |
my hood doesn't 'flutter' or 'flap' per se.
the sides of the hood forward of the strut humps will visibly raise up from the quarter panels about a 1/4"-1/2" at any speed over about 45mph. air is definitely running over the top of the headlights and raising up the hood lately i've noticed that the hood towards the front is about 1/8" raised over the side panels, and i could've sworn it was closer to flush/even when i originally got the car. my plastic front bumper, i've got no issues with alignment with the hood for that. but my plastic bumper cover is also pretty loose from curb strikes, so any alignment issues there are pretty easily faulted elsewhere.
| The Following 2 Users Say Thank You to soundman98 For This Useful Post: | Spuds (08-21-2022), Ultramaroon (08-21-2022) |
#20 | |
Sent from my SM-G781B using Tapatalk |
#21 |
THIS IS NOW A BITOG THREAD
![]() Maybe the corner stops are too high. I've never tried to see how far I can lower mine before they no longer touch the hood when latched. Hmmm...
| The Following User Says Thank You to Ultramaroon For This Useful Post: | soundman98 (08-21-2022) |
#22 |
Drives: 2017 BRZ Limited Perf. Pack
Double check that the small rubber bumpers out on the edges of the hood are adjusted too. These can help with fluttering out near the sides.
zoom zoom... wait wrong company
#23 |
AutoX-10/10ths every run
Maybe slow down? :P
| The Following User Says Thank You to whataboutbob For This Useful Post: | sato (07-06-2025) |
#24 |
Drives: X5 35d, D90, CX-5 Turbo
Looks pretty stable in this video, but maybe it is not showing the area that flutters?
#25 |
Though I have to admit, I always wondered about this gap above the headlamp and if it was sealed off to air flow or not. If not, maybe that is the issue?
(Yeah, I know the frontbumper is not fitting correclty in this photo, but it was the best one I could find quicklyh to show the gap I described) |
#26 |
There are seals, little angled flappy things mounted to the underside of the hood to route the air around the corners. I don't know how effective they are or if they're even in play here.
#27 | |
The Dictater
![]() ...I'll see myself out...
Also: "Build Thread" |
| The Following 4 Users Say Thank You to Spuds For This Useful Post: |
#28 |
| FS: Seibon Carbon TS hood, Sparco hood pins, Clear coated $650 (Lawndale) | iceblaze | Southern California | 1 | 04-14-2019 04:50 PM |
| Random fluttering/flapping sound when coming to a stop | retrosmiths | Issues | Warranty | Recalls / TSB | 24 | 10-08-2014 04:13 PM |
| Constant flapping sound from rear wheel side? | djmm | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 08-11-2014 10:36 AM |
| flapping noise | meekhotglass | BRZ First-Gen (2012+) — General Topics | 38 | 05-02-2013 11:44 AM |
| Fixed flapping, clanking sound coming from rear | Cornerman | Issues | Warranty | Recalls / TSB | 2 | 08-16-2012 10:27 PM |
