Old 08-20-2022, 12:07 AM   #1
SlwFRZ86
SlwFRZ86's Avatar
Drives: 17 brz limited
Hood flapping
im trying to remedy the hood fluttering above 95 mph. i dont really want to put in aero hood latches on the side.
what are some other potions to this or should i just deal with it
SlwFRZ86 is offline   Reply With Quote
Old 08-20-2022, 01:03 AM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Hood venting is the easiest way to get rid of the flutter
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
MrSkubi (08-24-2022), whataboutbob (08-20-2022)
Old 08-20-2022, 03:15 AM   #3
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Deal with it, its normal. If you run an aftermarket hood then get aerocatch or similar quality latches.
'13 WRB BRZ ~470whp // Instagram // YouTube
BRZoomTX is offline   Reply With Quote
Old 08-20-2022, 10:29 AM   #4
Adjust it. It isn't hard to do.
Just use the oval holes in the latch to move it up a hair. Don't get carried away though or then it will be hard to open.
Dadhawk (08-20-2022), Ultramaroon (08-20-2022), villainous_frx (08-21-2022), x808drifter (08-22-2022)
Old 08-20-2022, 08:54 PM   #5
Down. Move it down a hair. Make sure your corner stops are adjusted accordingly. It's not normal. My hood's rock solid up through a buck fifteen.
sato (07-06-2025), Spuds (08-21-2022), x808drifter (08-22-2022)
Old 08-20-2022, 11:40 PM   #6
Yes down. Not sure why I said up. Must have thought it was an Australian car.
sato (07-06-2025), soundman98 (08-21-2022), Ultramaroon (08-20-2022), Wally86 (08-22-2022), x808drifter (08-22-2022)
Old 08-21-2022, 12:01 AM   #7
You were still shocked at 600 ppm molybdenum.
Old 08-21-2022, 01:31 AM   #8
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
What if you are at the bottom and still get flutter?
Old 08-21-2022, 01:45 AM   #9
600 and I wouldn’t bat an eye. It was 1033 against an average of 189 and yes that is huge.
Old 08-21-2022, 01:46 AM   #10
Hammer the bar on the hood up. Yes this time it would be up.
Spuds (08-21-2022)
Old 08-21-2022, 01:48 AM   #11
Would have to figure out what's different. I've never even seen it.
Spuds (08-21-2022)
Old 08-21-2022, 03:28 AM   #12
No, 600 and 1000 are two samples of the concentration in the first fill with assembly lube. It's not even remarkable to me.
Old 08-21-2022, 10:35 AM   #13
The product called Liquid Moly is 180 and that is considered high.
Assembly lubes can go as high as 400 and should be diluted from there.
The samples posted are well above that.
My point remains that the guys that run home with their new car and drain out all that “crap” initial fill shouldn’t be in such a rush.
https://www.liqui-moly.com/fileadmin...Molygen_EN.pdf
bcj (08-21-2022), Ultramaroon (08-21-2022)
Old 08-21-2022, 10:42 AM   #14
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Corner stops are way off.
The Following 3 Users Say Thank You to Sapphireho For This Useful Post:
Spuds (08-21-2022), Tcoat (08-21-2022), Ultramaroon (08-21-2022)
FS: Seibon Carbon TS hood, Sparco hood pins, Clear coated $650 (Lawndale) iceblaze Southern California 1 04-14-2019 04:50 PM
Random fluttering/flapping sound when coming to a stop retrosmiths Issues | Warranty | Recalls / TSB 24 10-08-2014 04:13 PM
Constant flapping sound from rear wheel side? djmm Scion FR-S / Toyota 86 GT86 General Forum 12 08-11-2014 10:36 AM
flapping noise meekhotglass BRZ First-Gen (2012+) — General Topics 38 05-02-2013 11:44 AM
Fixed flapping, clanking sound coming from rear Cornerman Issues | Warranty | Recalls / TSB 2 08-16-2012 10:27 PM
