Old 07-19-2022, 09:20 PM   #15
Nfsundrgrnd
Nfsundrgrnd's Avatar
Drives: 2013 WR blue sport tech BRZ
Originally Posted by jrhudson View Post
Doesn't sound like anything is really off. does the noise change when you rev? was this noise only when its cold or warmed up?
try to get those videos of outside the car. help us help you. get video of under car, under the driver side see if you can't pick up the noise or anything from there but yea it doesn't sound terrible, just weird.
edit: also why do you think its injectors? if i heard a sound from the footwell of my car, i figure it was something closer to that area. vacuum hose/line?
I just assumed it was the DI pump acting up because it seemed to pulse at the exact same time as the DI, also when I shut the car off the noise whines down with the rpms/combustion cycles if that makes any sense so that's another thing.
I'm not too concerned by it yet since it seems to come and go like the crickets do but if it keeps getting worse I'd be more concerned.
It's barely audible anywhere but in the cabin, all the other mechanical noises and exhaust seem to cover 90% of it up on the outside.
Noise seems to be most present at mid temp, somewhere between fully warmed up and cold but happens when warmed sometimes as well.
Nfsundrgrnd is offline   Reply With Quote
Old 07-20-2022, 02:35 AM   #16
radroach
Drives: car
I used to hear the bubble noise all the time when my car was brand new, like 7+ years 130,000 miles ago. I have no idea what causes it but I used to love the sound.
The Following User Says Thank You to radroach For This Useful Post:
Nfsundrgrnd (07-20-2022)
Old 07-20-2022, 08:27 AM   #17
Nfsundrgrnd
Yes Bubble noise is a perfect way to describe it! Glad to hear it turned out to be nothing major. How long did it last before it eventually went away?
Old 07-20-2022, 03:28 PM   #18
Wait! WAIT!
Pulses with engine.
Started with warmer weather.
Audible in cabin but not engine bay.
Occurs in mid range temperatures.
Winds down when engine is shut off.
Bubbling noise.
A/C evaporator in dash. Next time you hear it open you glove box and listen closely in there.
Old 07-20-2022, 04:21 PM   #19
Nfsundrgrnd
Wait! WAIT!
Pulses with engine.
Bubbling noise.
This is a great suggestion! Next time I hear it I will check for that and update you guys! Appreciate the help!
Old 07-25-2022, 05:06 PM   #20
Nfsundrgrnd
Just an update to the situation, it seems @Tcoat might've been right. Last time I heard it, I shut the AC off then on again and I haven't heard it since then. Sound immediately stopped when I shut the ac off. I hadn't used the AC this summer up until last friday. If it comes back I'll be back lol.
The Following User Says Thank You to Nfsundrgrnd For This Useful Post:
Tcoat (07-25-2022)
My FRS 2013 Automatic Is Making Sounds When I Brake Ali3583 Engine, Exhaust, Transmission 3 06-21-2021 07:40 PM
Worse gas mileage than usual ephemerality Scion FR-S / Toyota 86 GT86 General Forum 56 06-24-2019 04:09 PM
Car won't start! Making weird sounds. B_Rad Issues | Warranty | Recalls / TSB 35 01-25-2017 06:33 PM
BEST of Start Up sounds!! More than 70 Exhaust Sounds! JPxM0Dz Other Vehicles & General Automotive Discussions 5 01-08-2014 03:24 PM
Business as usual at Scion Canada HQ colHolm Scion FR-S / Toyota 86 GT86 General Forum 5 07-04-2012 10:17 PM
