BRZ Second-Gen (2022+) -- General Topics General topics for the second-gen BRZ |
07-13-2022, 04:32 PM | #15 |
Drives: 2022 BRZ coming
Thanks for all the feedback! Based on this feedback, I think maybe mine is underperforming.
The Following User Says Thank You to Grosbard For This Useful Post: | Pete (07-13-2022) |
07-13-2022, 04:52 PM | #16 |
Drives: 2009 MX-5
Mine works great. In fact it gets so cold I have to turn it down and direct the vents away from me. We have had weeks where the weather is above 90 and heat indexes over 100.
07-13-2022, 08:04 PM | #17 |
Drives: 22 BRZ
You are not the only one, mine has been a bit on the weak side too. It has been much hotter than normal this year so I figured that was the problem, but now based on this thread I am wondering if I need some coolant to get it up to speed. Thanks for asking the question.
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
07-14-2022, 09:23 AM | #18 | |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
The Following 3 Users Say Thank You to BirdTRD For This Useful Post: |
07-14-2022, 09:32 AM | #19 | |
The bigger variations would be with leakage and driving type. Those that mess with their engine bays may be creating small leaks and lose a bit of pressure. AC system fittings can be temperamental. Driving around the city at lower RPMs may give a false impression that the AC is ineffective. Hit the highway and bring the revs up and you may find it is bloody cold all of a sudden. Even the second gen is still a small displacement engine that never plays well with AC even under the best of conditions so there can be quite a difference from car to car.
The Following User Says Thank You to Tcoat For This Useful Post: | Ultramaroon (07-14-2022) |
07-14-2022, 09:46 AM | #20 | |
Drives: 22 BRZ limited
The Following User Says Thank You to dragoontwo For This Useful Post: | Tcoat (07-14-2022) |
07-14-2022, 09:51 AM | #21 |
Good point. They could very well be wringing every bit of power they can out of it by shutting the AC down more often. Even a couple of seconds off can increase temps in the car quickly.
07-14-2022, 11:30 AM | #22 |
chicken tonight
Same as first gen.
07-15-2022, 05:25 AM | #23 | |
Drives: '04 STi, '12 Mazda 3 Hatch
Can you clarify this? Did you mean the opposite? What would make sense is the compressor disconnecting* during WOT, or even above some throttle percentage like 75%. *A/C compressors usually have an electric clutch to engage or disengage from a pulley that is always being spun by a belt. |
07-15-2022, 06:59 AM | #24 | |
07-15-2022, 12:19 PM | #25 |
chicken tonight
[s]My AC only works when I'm mashing the gas pedal[/s]
07-16-2022, 10:11 AM | #26 |
I have a Gen 1 BRZ
Pressing the RECIRCULATE switch maximizes the cooling. The aircon struggles when pulling in 99 degree air from outside Works fine until someone farts. |
The Following User Says Thank You to g e For This Useful Post: | Tcoat (07-16-2022) |
07-16-2022, 02:26 PM | #27 |
chicken tonight
Unless one is alone in the cabin. Then it's glorious.
07-16-2022, 04:31 PM | #28 |
helmholtz resonator
Drives: '15 ultramarine
Similar Threads | ||||
Aircon blowing cold on one side | Kris86 | Issues | Warranty | Recalls / TSB | 9 | 05-12-2020 12:36 PM |
Cost Effectiveness of Modifying Your Car | Tristor | BRZ First-Gen (2012+) -- General Topics | 12 | 09-22-2018 11:22 PM |
Dual Zone AirCon Operation | Esseff | Scion FR-S / Toyota 86 GT86 General Forum | 34 | 05-01-2017 06:05 PM |
Effectiveness of a Lightweight pulley | DrifterX | Engine, Exhaust, Transmission | 94 | 12-11-2016 01:10 AM |
Swap Aircon HVAC controls from BRZ/GTS to FRS/GT | MudithJ | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 08-04-2016 10:13 AM |
