Old 07-01-2022, 12:16 PM   #1
ss600
Drives: 2022 Crystal Pearl Subaru BRZ
Too tall in '22 BRZ at first track day - Options?
Hi All - Long time lurker here, posting to see about options/ideas for tall people. I bought the BRZ because I liked the coupe and I basically don't fit in a Miata at 6'2". All was good, loving the new car. Exhaust, ceramic coat done.
First track day yesterday. Aside from melting the stock PS4's, the biggest issue I had was that I had to lean the seat waaay back to fit in and not knock my head around with a track helmet on. The track we have here is tight and lots of turning. I felt like I was not secured by the seats AT ALL and subsequently bruised both knees badly trying to hold myself in. This doesn't happen as much when the seat is more upright.
So I'm flying all over the seat and on top of that, the steering wheel is too far away and I really didn't like the way the ergos felt in that position.
What are my options here? Lower the seat (is this possible?)? Race seat (also daily it so don't want to lose airbags? Buy a bigger car? I also have a c6 corvette and I fit in that no problem (big 'murica car). One guy at the track told me there is a seat belt clincher that tightens it up a lot?
Looking for any opinions/ideas. Thanks!
ss600 is offline   Reply With Quote
Old 07-01-2022, 12:36 PM   #2
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I'm 6'0". In my first track session with my 2013 FRS, I didn't realize that I could lower the seat with the handle on the left side below the seat back adjustment (lol). I also found that I could reverse the head rest which allows me to sit up straighter. When I drive, I wear "minimalist" shoes. I feel the pedals better and it allows me to bring the seat forward just a little bit more. It still a tight fit with a helmet on. When I upgrade my helmet, I'll try to find one that not too tall, if "they" make one. I have a CG lock on my seatbelt. It keeps me planted but unfortunately I don't think they are available anymore.
Old 07-01-2022, 05:11 PM   #3
otter
Drives: 22 BRZ
I'm assuming you used the stock adjustment to lower the seat, but if not... lower the seat. I'm the same height as you, and variances in leg/torso proportion aside, you should have no issue sitting normally in the car with a helmet.
otter is offline   Reply With Quote
Old 07-01-2022, 09:59 PM   #4
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
https://www.ft86club.com/forums/showthread.php?t=148128
Follow the build thread for my GR86!
The Following User Says Thank You to timurrrr For This Useful Post:
DarkSunrise (07-02-2022)
Old 07-02-2022, 12:27 AM   #5
DarkSunrise
DarkSunrise's Avatar
Originally Posted by timurrrr View Post
Thanks for posting that. I tried my helmet in my BRZ2 the other day and was surprised to find I had less headroom. In my preferred seating position my helmet is just grazing the roof, whereas I had a good amount more headroom in my FRS. Luckily I think I can make it work, but it’s a difference I didn’t expect.
2022 BRZ Build
2013 FR-S Build
Old 07-02-2022, 11:44 AM   #6
ss600
Thanks, I'll definitely check this but I think it's all the way down. It could have been an abnormally tall helmet. Another guy with a '22 BRZ was there and he was about 6 feet tall and having similar issues. I think helmet choice will be an impacting factor as well.
I had assumed someone would have made a lowering bracket but I can't seem to find anything.
Old 07-03-2022, 06:32 PM   #7
Angrypuppy
Drives: 2022 BRZ Limited on order
I’m 6’2” my kid is 6’4”, we co-drive the car at the track. We both have long legs and proportionally shorter torsos but don’t find it too tight. He is at the edge but it works. Seat for either of us is not excessively reclined. I wear an Ariai he wears a Bell.
Angrypuppy is offline   Reply With Quote
Old 07-05-2022, 12:41 PM   #8
yEEt42069
Drives: 2018 Subaru BRZ
I had issues with helmet rubbing on roof with stock seat and I tried stretching the springs underneath the seat but it didn't work. In the end, I installed a bucket seat with PCI sliders and its perfect, no more rubbing.
yEEt42069 is offline   Reply With Quote
Powertrain options for track only GrandSport Engine, Exhaust, Transmission 15 06-02-2022 08:39 AM
Transmission upgrade options for stock power and track only use? GrandSport Tracking / Autocross / HPDE / Drifting 46 02-24-2021 05:57 PM
UEL+track pipe too loud - single left exhaust options? Wiscocrashtest Engine, Exhaust, Transmission 11 09-12-2018 01:33 PM
Quieter (<93db) track muffler options for header/single hi-flow cat dp1 Engine, Exhaust, Transmission 37 07-04-2016 09:02 PM
How tall are you djmm Scion FR-S / Toyota 86 GT86 General Forum 122 12-26-2013 04:05 PM
