Old 06-16-2022, 05:05 PM   #1
blakkoutdarko
blakkoutdarko's Avatar
Drives: 2017 Toyota 86 (Raven)
Hit a curb after swinging it, what parts to replace.
If you live in South Florida you know how bipolar the weather can be so while it was lightly drizzling i was leaving a Target parking lot and tried to swing a corner that i usually do every time i leave the store. In the end i ended up with a broken Rays Gram Lights 57DR and a bent passenger side front control arm. When taking the wheel off it gives the hub sort of a negative camber. Then when putting the spare on i was hearing sort of a scraping noise..not metal to metal scraping but sort of like it’s rubbing against something in the wheel well. Not to sure what my friend couldn’t see what it was hitting either. But so far i know for a fact i need a new front LCA, any brand recommendations would be greatly appreciated.
blakkoutdarko is offline   Reply With Quote
Old 06-16-2022, 05:12 PM   #2
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Subaru 20202CA002. $174.26 + shipping.
Toyota SU00310055. $179.65 + shipping
The Following 2 Users Say Thank You to dragoontwo For This Useful Post:
blakkoutdarko (06-17-2022), ZDan (06-17-2022)
Old 06-16-2022, 06:15 PM   #3
gkubed
gkubed's Avatar
Drives: 15 ZN6, 97 NA8, 87 AE82, 78 MX32
Time to upgrade to SPL.
gkubed is offline   Reply With Quote
The Following User Says Thank You to gkubed For This Useful Post:
Jdmjunkie (06-17-2022)
Old 06-17-2022, 08:47 AM   #4
Grady
Grady's Avatar
You are the only one that can answer that. Take it apart and inspect for damage, replace any part that is damaged.
The Following User Says Thank You to Grady For This Useful Post:
RToyo86 (06-17-2022)
Old 06-17-2022, 09:29 AM   #5
Check the hub. The weird noise you hear could be bits of smashed bearing.
blakkoutdarko (06-17-2022), Grady (06-17-2022), RedReplicant (06-17-2022), Ultramaroon (06-17-2022)
Old 06-17-2022, 11:52 AM   #6
Grady
Grady's Avatar
Yes, hubs are tough but a hit like that can dent the race and you will have an early failure.
Tcoat (06-17-2022)
Old 06-17-2022, 01:29 PM   #7
blakkoutdarko
dent the race? what’s that?
Old 06-17-2022, 01:35 PM   #8
The part that the actual bearing components roll on. Even a slight dent, split, or even a crack can screw it up. They don't take side impacts well. Damage to a bearing will give a sort of swishing sound much like you described.
Old 06-17-2022, 04:11 PM   #9
RedReplicant
Drives: None
Nah, leave the weak stamped steel for the next time he does it. Better to replace an arm than a subframe.
RedReplicant is offline   Reply With Quote
Old 06-17-2022, 08:23 PM   #10
blakkoutdarko
Ok Tcoat bear with me, i’ve done a lot of work around this car and that’s involving replacing all the stock studs with ARPs and i don’t recall seeing that. Where can i find that “race” or “bearing” on the car? The wheel hub? Wanna check it before the sun goes down
Old 06-17-2022, 08:25 PM   #11
blakkoutdarko
Honestly not sure if that was a slick joke or if SPL doesn’t make quality control arms, haven’t heard anything fishy about them but always open to hear the good, bad and ugly
Old 06-17-2022, 08:38 PM   #12
RedReplicant
Drives: None
My point was that the stock stamped steel arms will bend in an impact, but generally preserve the subframe. Something like a SPL may very well transfer that impact force into the subframe and bend it too.
The Following User Says Thank You to RedReplicant For This Useful Post:
blakkoutdarko (06-18-2022)
Old 06-17-2022, 08:48 PM   #13
The race an bearing are inside the hub. Take the wheel off and spin just the hub. If the bearing is damaged you should know pretty quickly.
blakkoutdarko (06-18-2022), Spuds (06-18-2022)
Old 06-18-2022, 03:05 PM   #14
Personally, I'd just spin the wheel and listen. If you hear anything at all, even the slightest sound, the hub assembly is toast. Can't stress enough that bearings MUST run dead silent.
Spun a bearing, what parts do I need to replace? Daisies Scion FR-S / Toyota 86 GT86 General Forum 3 05-16-2022 12:29 PM
What parts would I need to completely replace entire suspension system? echomx Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 09-04-2020 11:47 AM
Having accident causing persons insurance replace aftermarket parts Chuckls BRZ First-Gen (2012+) — General Topics 37 02-03-2020 12:37 PM
What to check after swinging it Youngmanhenry Scion FR-S / Toyota 86 GT86 General Forum 47 04-06-2019 12:54 AM
What additional parts do I need to replace with my kaaz lsd install acpstunts Engine, Exhaust, Transmission 0 04-06-2017 11:43 PM
