| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: 2019 BRZ
2019 BRZ - rear clicking question:
Hi -
I hear a clicking noise at this point only when under power starting out in first gear and reverse gear (when there is significant torque being applied I guess). Here's the baselines: -100% stock, except it's on new Toyo Proxes Summer tires (similar to stock tires -6 speed manual -No AX or track events on BRZ -No clutch drops and minimal hard 1 to 2 while cornering -I do enjoy inducing mild oversteer on a frequent basis The click isn't bad or terribly annoying, just getting worse. Are there likely culprits for this issue? What can I potentially expect? THANKS Mike |
#2 |
Wheels for Brains
Try checking your axle nuts: retorque or replace them. Common issue on this platform.
Google "FRS BRZ Axle Click" to verify if it's the same noise. |
#3 |
Drives: 2019 BRZ
Thanks
#4 |
Drives: 2019 BRZ
Oh any symptom to look out for for an actual axle failure?
#5 |
Wheels for Brains
#6 |
Drives: 2017 PP BRZ
I had the same problem OP. Turns out it was my axle nut and the scissor jack moving around in the trunk. Hope this helps anyone in the future.
#7 |
Drives: 2019 BRZ
Hey just recuscitating this old topic:
I never got my axle nuts looked at. The problem diminished with cold weather and I procrastinated. What kind of problems can loose axle nuts create? I worry I may be costing myself a bunch of money unnecessarily. |
| Clicking noise from the rear | Seiryuu | Issues | Warranty | Recalls / TSB | 18 | 05-17-2020 09:07 PM |
| Clicking Sound From Rear (Axle?) | gonzo | Issues | Warranty | Recalls / TSB | 9 | 02-09-2020 01:26 PM |
| 2019 BRZ Fog Light Question | Lebby83 | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 08-05-2019 03:12 PM |
| Question about warranty work and steering clicking at low speed | JM197 | Issues | Warranty | Recalls / TSB | 5 | 07-20-2016 11:55 AM |
| Clicking coming from rear.. | HillCountryGuru | Issues | Warranty | Recalls / TSB | 3 | 03-22-2013 01:05 AM |
