Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 05-27-2022, 07:26 PM   #1
ZX88
ZX88's Avatar
Drives: 22 BRZ
Unhappy BRZ feels unstable after wheel and tire set up
I recently installed some 18x9.5+43 with Hankook Ventus V12 Evo2 (245/35/18). With some BC racing coilovers from my previous Gen 1.
This is my first time running a wider tire set up on one of these cars. The largest i've run in the past where 225/40s on a 9.5.
The car feels unstable on the highway and im constantly fighting it to keep it straight in the lane to the point where it just feels unsafe almost floaty like a sway.
I took the car in for an alignment since it felt like the toe might have been out in the rear but that did not seem to change much.
I know tramlining can be an issue with wider tires that are lower profile but i feel like this is a pretty common set up for these cars and i really haven't seen other people complaining about this.
Anyone running a similar setup what has your experience been?
Suspension is all stock arms and the front camber plate on the coilovers are zero out (so no excessive camber other than the nature camber from the modest drop).
I did install the coilovers and wheels the same day so ill be swapping the wheels back to stock to see if it is in fact tramlining.
[IMG][/IMG]
2013 TRD FRS
2017 TRD Toyota 86
2022 BRZ
ZX88 is offline   Reply With Quote
Old 05-27-2022, 08:14 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
If the car has any toe out, the larger width is going to exacerbate the tramlining. Have you gone to an alignment shop after installing the coilovers to get everything checked?
Old 05-27-2022, 09:49 PM   #3
ozafar
Drives: 2015 Scion FRS Release Series 1.0
Alignment was after the coilovers, right? Do you have a copy of the alignment results?
ozafar is offline   Reply With Quote
Old 05-27-2022, 10:05 PM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
can you post the alignment printout?
timurrrr (05-29-2022)
Old 05-27-2022, 10:37 PM   #5
ZX88
ZX88's Avatar
Drives: 22 BRZ
So i feel like an idiot. So i assume the place where i got my tires mounted would set the psi to somewhat oem. However every tire was above 50 psi and one of the rears was probably around 60 or 70 psi... which explains why it felt so washy....
Dropping it all down to 35 completely fixed the issue. Car feels great now.
2013 TRD FRS
2017 TRD Toyota 86
2022 BRZ
The Following 10 Users Say Thank You to ZX88 For This Useful Post:
Burrz (06-01-2022), DarkPira7e (05-28-2022), jongers (05-28-2022), Midnightsky (05-28-2022), Ohio Enthusiast (05-28-2022), PBR (05-28-2022), soundman98 (05-28-2022), Tcoat (05-27-2022), timurrrr (05-29-2022), Wally86 (05-31-2022)
Old 05-28-2022, 12:44 AM   #6
Midnightsky
Midnightsky's Avatar
Drives: 2022 BRZ WRB
Ouch, that is not so great for your tires......
Midnightsky is offline   Reply With Quote
The Following User Says Thank You to Midnightsky For This Useful Post:
Old 05-30-2022, 10:05 AM   #7
mr.whiskers
Drives: '22 BRZ
God damn, and here I am getting mad when tire places set mine to 40 psi
mr.whiskers is offline   Reply With Quote
The Following User Says Thank You to mr.whiskers For This Useful Post:
Old 05-30-2022, 01:09 PM   #8
2020BRZtS
2020BRZtS's Avatar
Drives: '20 BRZ tS (15/300) / '09 Scion tC
You might want to reach out to them and let them know. It could have been someone new that worked on your car and doesn't know any better. You have some pretty high speed limits down there and your cautiousness could be someone else's tragedy in the making.
2020BRZtS is offline   Reply With Quote
The Following User Says Thank You to 2020BRZtS For This Useful Post:
Old 05-31-2022, 09:52 AM   #9
otter
Drives: 22 BRZ
Basically just means the tech was lazy and didn't let the pressure drop back down after setting the bead.
otter is offline   Reply With Quote
The Following User Says Thank You to otter For This Useful Post:
Wally86 (06-01-2022)
2022 subaru brz, brz, te37 5x100
Spare tire for a week now car feels floaty / traction light goes off a bunch subaruslow Issues | Warranty | Recalls / TSB 23 06-16-2021 02:20 PM
Performance package wheel/tire weight vs. regular wheel/tire combo qqzj Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-26-2019 02:27 AM
JUST REPLACE THE NEW STEERING WHEEL/ FEELS SOOO GOOOD felix_tanggg Cosmetic Modification (Interior/Exterior/Lighting) 20 05-20-2019 12:12 PM
car feels funny after changing to summer tire/wheels theman233 Issues | Warranty | Recalls / TSB 4 04-02-2017 02:48 AM
Unstable feeling Toyobaru808 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 06-28-2013 12:06 PM
