Old 05-17-2022, 03:59 PM   #141
ka-t_240
Originally Posted by steverife View Post
I'm with Ken. One could make the argument that the CAE isn't legal because the trimming and there are limited places in the rules where trimming to allow legal parts is specified (rear strut bar, shock adjustments, etc).
...but I can't really see anybody caring about it if you put a boot on the shifter. I certainly don't care.
Haven't there been people getting upset about missing that silly "engine cover" on these cars in STX before? What seems small, may not be worth the headache if someone cares to go to 'big' events.
ka-t_240 is offline   Reply With Quote
Old 05-17-2022, 04:06 PM   #142
e1_griego
e1_griego's Avatar
Drives: Many
And trunk foam.
e1_griego is offline   Reply With Quote
Old 05-17-2022, 04:30 PM   #143
steverife
Drives: 2016 Scion FRS
I haven't heard that.
Plus it is legal to remove a plastic engine cover if it only serves cosmetic or acoustic purposes.
steverife is offline   Reply With Quote
The Following User Says Thank You to steverife For This Useful Post:
DocWalt (05-23-2022)
Old 05-17-2022, 05:24 PM   #144
Eric1855
Drives: LP DSP / CSP '13 BRZ
SCCA Rule Book 14.10 (I)
I. Upper engine shields made of plastic material, the purpose of which
is to hide mechanical components in the engine compartment, may be
removed if they have a solely aesthetic and/or acoustic function.
In ST though, not Street. Emblems may also be removed now in ST, which was a historical boogeyman issue.
For trunk foam it depends, rule states in Street, which then carries over to ST that....
F. Spare tires, tools, and jacks may be removed. Any fastening hardware and/or other pieces that can no longer be fi rmly secured in the absence of the spare tire may be removed if necessary to ensure compliance with
so if its not bolted or clipped to the car without the tire it can be removed, if it is it needs to stay. So on the BRZ for example the stuff on the sides needs to stay, but the big foam ring the sits in the middle of the spare can go.
Eric1855 is offline   Reply With Quote
The Following User Says Thank You to Eric1855 For This Useful Post:
Old 05-24-2022, 12:23 PM   #145
ka-t_240
is anyone running one of the nameless mufflers with the stock midpipe? Curious on sound/noise on the STX cars. I heard one of their smaller one last weekend and it wasn't bad, but the car was still on stock header.
Old 05-24-2022, 12:26 PM   #146
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Buddy of mine is using one with ACE header & otherwise stock exhaust. Sounds great, passes sound anywhere.
Old 05-24-2022, 03:41 PM   #147
ka-t_240
Do you know which version?
The single exit or the ultra quiet?
Old 05-24-2022, 08:33 PM   #148
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Has twin tips, 5" mufflers.
Old 05-25-2022, 06:02 AM   #149
steverife
I was thinking of the Nameless track pipe or delete or whatever you call all. And my answer was lord, no.
The Following 3 Users Say Thank You to steverife For This Useful Post:
DocWalt (05-25-2022), ka-t_240 (05-26-2022), strat61caster (05-25-2022)
Old 05-25-2022, 10:53 PM   #150
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I’ve got the single exit ultra quiet track pipe with header and stock midpipe and I’m pretty happy with it. I didn’t like it at first but turns out it was mostly header rub lol.
https://shop.namelessperformance.com...et-track-pipe/
I actually had the dual exit with the 5” mufflers and I hated it, bad resonance at cruising rpm with a header, it was used so maybe it was blown out but I sold it after a few months.
ineedyourdiddly
NoHaveMSG (05-25-2022)
Old 05-26-2022, 03:56 PM   #151
ka-t_240
I know better than to ask about the delete ahaha. How to make a FA20 sounds even worse... lol
Old 05-26-2022, 04:20 PM   #152
ka-t_240
There was a SSC car with this at a recent event and it was surprisingly quiet and wasn't terrible sounding.
https://shop.namelessperformance.com...-pipe-brz-frs/
Old 05-27-2022, 12:43 AM   #153
strat61caster
SSC keeps the catalytic converters in the car. They don’t sound bad with minimal mufflers and cats, pulling one cat out for ST* is a big leap in noise, basically removing the cats or the mufflers doubles the noise, removing both quadruples it. Probably won’t blow sound at most scca events with headers + minimal/no mufflers and oe midpipe (between 95-100db depending on the site/region) but I know I don’t like cars that loud.
Hell I’d keep the stock mufflers if my jack could fit under it, but fitting the jack and dropping 15# is worth it most of the time.
ineedyourdiddly
Old 05-27-2022, 01:19 AM   #154
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I have the ultra quiet track pipe too with catless header and 3” catted FP. People are surprised how tame it is.
strat61caster (05-27-2022)
The 2022 Autocross Thread trippinbillies40 Tracking / Autocross / HPDE / Drifting 11 02-26-2023 06:13 AM
STX setup sharing thread (2021) Autoxer62 Tracking / Autocross / HPDE / Drifting 366 12-07-2021 02:57 PM
STX setup sharing thread (2020) Autoxer62 Tracking / Autocross / HPDE / Drifting 389 12-29-2020 02:40 PM
STX setup sharing thread (2019) CoolHandMoss Tracking / Autocross / HPDE / Drifting 109 02-17-2020 12:27 PM
STX Set-Up Sharing & Results Thread race2win Tracking / Autocross / HPDE / Drifting 76 02-16-2017 12:30 PM
