Old 05-16-2022, 06:15 PM   #1
larryt
Drives: 2018 BRZ
Lead in Oil
I received my Blackstone report from my last oil change. Lead was at 4ppm, which is indicated as a little high (3627 miles on oil). They indicate that lead usually comes from bearings, but that they understand this engine has aluminum bearings. Is that true? Other wear metals looked good. The report indicated that maybe the lead was from leaded fuel or additives, neither of which we use. I have a sample from my last change that I did not send in, but I think i will to see if this was a one off situation.
Any thoughts from anyone about the possible source of lead? Is there anything in the engine it could come from?
Thanks.
larryt is offline   Reply With Quote
Old 05-16-2022, 07:24 PM   #2
Ashikabi
Ashikabi's Avatar
Pretty sure all has a little lead in it. I'm sure Google can verify that
Sent from my ONEPLUS A5010 using Tapatalk
Old 05-16-2022, 07:27 PM   #3
fminicooper
Drives: FRS Hot Lava
Happened to me. The source was just filling a couple of gallons of race gas (with lead), enought to come in the blackstone report.
fminicooper is offline   Reply With Quote
Old 05-16-2022, 07:56 PM   #4
Yes it may have a little that is why they have a "normal" limit that he is over.
I wouldn't sweat it over one test that is marginally over the norm. If it is still over on the next test it would be more concerning. You can get small amounts of lead from the solder joints, anti seize and other similar sources.
Old 05-16-2022, 09:00 PM   #5
larryt
Drives: 2018 BRZ
Now that you mention it we did fill it at the track, about two tanks before the oil change, but it 93 octane pump gas. I assumed it was unleaded, but I am not sure. I honestly do not know what the track dispenses aside from what the octane levels are. I'll be sure to look more closely next time.
Old 05-16-2022, 09:01 PM   #6
Ashikabi
Ashikabi's Avatar
Maybe uses the same hose?
Old 05-16-2022, 11:44 PM   #7
fminicooper
There you have your source.
Go to sleept like a baby...that issue kept me thinking lot of nights...
Where does the track rabbit hole lead? Ohio Enthusiast Tracking / Autocross / HPDE / Drifting 59 08-21-2021 11:59 PM
AGM vs Lead Acid battery go_a_way1 Engine, Exhaust, Transmission 15 01-19-2017 12:18 AM
Ignition lead for dyno? jedibow Engine, Exhaust, Transmission 6 08-06-2015 10:44 PM
Parking brake lead problem? BRZ'13 Issues | Warranty | Recalls / TSB 7 07-28-2014 02:42 PM
Stretching will lead to a firey death frosty86 Off-Topic Lounge [WARNING: NO POLITICS] 6 10-19-2012 04:31 AM
