Drives: 2020 BRZ
Revert FRS from push to start to regular key ignition
I bought a shell but the previous owner had installed a push to start(easy guard), I’d like to remove it and put it back to a key ignition would I just have to buy a steering column ignition assembly or do I have to buy all new ECUs and a whole new dash harness, I’m just trying to fix this because the shell was given to me with no keys
Thanks for reading and I appreciate any info! |
#2 |
There might be a key hidden in the steering column to defeat the immobilizer. I had a push start installed on mine for a while and it was not hard to revert. Essentially just unplugged it and respliced a wire in the ignition switch loom that was split. If you can't find a key that works, maybe a locksmith can help you make a new one
Sent from my ONEPLUS A5010 using Tapatalk |
#3 | |
Drives: 2020 BRZ
#4 |
ProCrastinationConsultant
what does the vin decode as? limited or premium?
#5 | |
#6 |
Drives: 2020 BRZ
#7 |
#8 |
Drives: 2020 BRZ
#9 |
| Stall/No Re-start with push button start | couver | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 06-26-2020 10:32 PM |
| Help! STI push start button / Ignition switch | Busybee | Cosmetic Modification (Interior/Exterior/Lighting) | 11 | 06-05-2020 01:55 AM |
| FS: STI engine start push start OEM plug and play | sokol | Interior Parts (Incl. Lighting) | 5 | 06-13-2019 02:12 PM |
| Battery dies, push start car in gear.... push start button | rhythmM | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 02-27-2014 06:06 PM |
| Push Start Rough Engine Start Up | joergasm | Engine, Exhaust, Transmission | 3 | 12-12-2012 03:44 AM |
