| Member's Car Journals Car journals by our members. |
Drives: Subaru BRZ
2022 Subaru BRZ hpde build
Ordered on 10/22/2021, picked up on 4/15/2022.
Premium trim, not a single accessory, just like I wanted. This may turn out to be a more serious build than the previous one (from which many mods will transfer). Up-to-date mod list: Tomei oil pan baffle -- MCS coilovers, 650/700 springs Whiteline KCA416 camber bolts Megan Racing OEM FLCA with spherical bushings and +15mm RCA Hardrace RC tie rod ends +15mm Karcepts FSB STi flexible v-bar RacerX rear UCA MCA Suspension 86 Traction Mod Removed RSB -- APR 61" GTC-300 wing custom splitter DocWalt GR86 Cup replica hood vent -- Jacks Transmissions transmission @13,625 miles ACT 6 puck clutch Verus clutch fork and pivot STi transmission mount Cusco motor mounts -- AP Racing CP9660 Radi-CAL front BBK AP Racing CP9451 Radi-CAL rear BBK Ferodo DS3.12 brake pads -- Advan Racing RS III, 18x9 +50 KYO-EI Project Kics Spacers 20mm in front ARP wheel studs 255/35/18 tires du jour -- Outbound Motorsports GR86 Cup intake JDL EL header, overpipe, ultra quiet front pipe CSG Spec Touring 86 catback Gerald Just flex fuel kit Tuned by Zach@CSG -- GSpeed roll bar OMP HTE-R 400 seats PCI seat rails Schroth 6-point harnesses REAL leather steering wheel Last edited by Code Monkey; 12-31-2024 at 02:26 PM. |
| The Following 11 Users Say Thank You to Code Monkey For This Useful Post: | alphasaur (05-16-2022), DarkSunrise (05-05-2022), dowroa (04-18-2022), Espi (05-02-2022), JD001 (09-29-2022), Opie (05-03-2022), PulsarBeeerz (05-16-2022), RedReplicant (05-16-2022), TheBoss77 (06-20-2022), thedollarbill (04-19-2022), villainous_frx (04-18-2022) |
#2 |
Drives: Subaru BRZ
Lots of wrenching this month on both BRZs with the goal of taking the red BRZ to Road Atlanta on May 21-22.
Transferring over from the Series.Yellow: MCS coilovers RacerX rear UCA MCA Suspension 86 Traction Mod STi flexible v-bar OS Giken LSD, 4.3 gears STi transmission mount Dropped off the dampers today for service at MCS, should be ready next week. Used 550/550 springs before, will be running 550/650 springs. Ordered the AP Racing CP9660 Radi-CAL front brake kit with Ferodo DS1.11 pads, should be arriving next week. Still need to source OEM 18" wheels and pick decent 225/40/18 tires. Last edited by Code Monkey; 05-23-2022 at 10:54 AM. |
#3 |
Drives: Blue BRZ
Would you please elaborate on wheel choice?
Many people are going for wider 17”. |
#4 |
Drives: Subaru BRZ
Need to accommodate the Radi-CAL BBK. OEM 18" wheels will work for now. I will figure out proper 18x9.5 or so later.
| The Following User Says Thank You to Code Monkey For This Useful Post: | Krokodil (05-03-2022) |
#5 |
Drives: Subaru BRZ
Picked up dampers from MCS, two day turnaround!
Service note: Both front guides needed replacement which is not a abnormal wear item on the BRZ chassis. The strut is relatively short on this chassis and the angle is fairly steep so it tends to wear the guide. |
| The Following User Says Thank You to Code Monkey For This Useful Post: | jongers (05-05-2022) |
#6 |
Drives: 19 86, 22 BRZ
nice choice of mods - looking forward to your build
| The Following User Says Thank You to jongers For This Useful Post: | Code Monkey (05-05-2022) |
#7 |
Drives: Subaru BRZ
Got 18" wheels from the limited trim. Plenty of clearance for the Radi-CAL calipers.
#8 |
Drives: Subaru BRZ
Radi-CAL brakes installed and bled with Castrol SRF, rear diff with OS Giken and 4.3 gears swapped in, and CSG Spec Touring 86 catback installed as well. 715 miles on the car.
Tackling coilovers this weekend with an alignment scheduled Monday. |
| The Following 3 Users Say Thank You to Code Monkey For This Useful Post: |
#9 |
Off to the track!
Drives: '14 Lava 86, '13 WRB BRZ
0-100 real quick, loving these updates!
| The Following User Says Thank You to villainous_frx For This Useful Post: | Code Monkey (05-13-2022) |
#10 |
You got right to it! Looking forward to seeing the progression.
| The Following User Says Thank You to KillerBMotorsport For This Useful Post: | Code Monkey (05-13-2022) |
#11 |
Drives: 2022 GR86 Premium Track bRed
Lots of serious components!!
What made you want to change differentials? Is the OS Giken more suited to the gearing you need for your track of choice or did you just do it for durability? |
#12 |
Drives: 23 BRZ
I'm curious as to why you chose the Radi-CAL over the smaller/lighter/cheaper Sprint or Endurance kits from AP Racing. Thanks!
#13 | |
Drives: Subaru BRZ
Buy once, cry once. Just driving around rural GA the stopping performance is mind blowing. |
| The Following User Says Thank You to Code Monkey For This Useful Post: | villainous_frx (05-16-2022) |
#14 |
Drives: Subaru BRZ
Suspension bits installed at 825 miles, alignment at 840 miles. Was hoping for more camber in front and could see -4.1 on the alignment rack, but once everything was tightened, could not get more than -3.5 on the passenger side.
Measured OEM ride height at approximately 6" pinch weld to floor. Dropped both front and rear 1" as scientifically measured by the coffee can (5.04" tall). Almost ready for Road Atlanta this weekend. |
| 2017 Subaru BRZ hpde build | Code Monkey | Member's Car Journals | 207 | 04-18-2022 11:11 AM |
| 2022 BRZ JDM Spec build at HKS USA for SEMA2021 | 143 | BRZ Second-Gen (2022+) — General Topics | 5 | 02-14-2022 01:27 PM |
| redSerpente’s HPDE/86CUP Street build | redSerpente | Member's Car Journals | 10 | 04-26-2021 07:50 PM |
| LS3 HPDE / Time Attack Build | RavioliG | Member's Car Journals | 17 | 02-11-2018 04:56 PM |
| 86_Freak - Build for DD/C Street/HPDE duties | 86_Freak | Member's Car Journals | 3 | 03-07-2016 10:15 AM |
