Old 04-08-2022, 06:13 AM   #1
XenoKing
Drives: Toyota 86 TRD Special Edition
Question Rattling at idle
I just bought my 86 and found after starting the car when it idles out there is a loud rattling noise in the cabin coming from under the car. It's only when idling. Any idea's?
XenoKing is offline   Reply With Quote
Old 04-08-2022, 06:33 AM   #2
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Depress the clutch to see it if goes away.
These transmissions can be noisy at idle as the backlash in the gears goes clack clack. It's audible with the GF-3 molasses the car comes with and it's even more so if the gearbox oil has been changed for higher quality synthetic fluid, I'm running amsoil mtg 75w90 and yeah, clackitty clack clack :lol
Old 04-08-2022, 11:29 AM   #3
XenoKing
I tried it but nothing changed, its coming from under the backseat console area. once i take off its gone but comes back when i park.
The Following User Says Thank You to XenoKing For This Useful Post:
humfrz (04-08-2022)
Old 04-08-2022, 01:32 PM   #4
Welcome, XenoKing, to ....... The Forum -
I suggest you put your car up on a lift and see if you can figure what is lose under there. Maybe a panel, maybe a part of the exhaust is banging on something?
Maybe something under the mat in the trunk?
Old 04-08-2022, 03:29 PM   #5
If you can capture the sound, post a clip on ewe toob and link here.
Old 04-08-2022, 08:20 PM   #6
Grady
Grady's Avatar
Any modifications? Lightweight flywheels cause more noise.
Old 04-09-2022, 02:54 AM   #7
XenoKing
Here is my video of the cars drone/rattle
https://youtube.com/shorts/AQyMwFodvZg?feature=share
Old 04-09-2022, 04:10 AM   #8
Sounds like exhaust ... something. Could be an internal part of the muffler rattling. Doesn't sound like a leak but I wouldn't rule out anything. I'd back it up onto a pair of ramps and listen from underneath.
Old 04-09-2022, 09:42 AM   #9
soundman98
ProCrastinationConsultant
soundman98's Avatar
check your heat shields under the car. first thing that likes to corrode and drop usually..
Old 04-09-2022, 11:34 AM   #10
RZNT4R
I don't know if I'm hearing the same thing you're hearing but...
... Lower the rear backrest, see if you hear it more.
The dull slapping that seems to match the exhaust pulses may be coming from the rear body vents hidden behind the rear bumper in the corners of the trunk. At idle, exhaust resonnance can make the flaps oscillate in time with the pulses. I know my stock 86 with stock exhaust does it when I park it home backed to a brick wall. Your car with the obviously loud exhaust may be more severe.
Old 04-09-2022, 03:22 PM   #11
If that's the case, closing the windows and running the blower would at least change the sound if not eliminate it. Interesting.
Old 04-18-2022, 11:40 PM   #12
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
There's a clamp that holds the exhaust to the car that has come loose on me a few times and makes a rattle noise. I've hit it going over speed bumps a few times and that makes it come loose.
B-R-Z is offline   Reply With Quote
idle, rattle, toyota, toyota 86
Rattling when decelerating ALWYZBZ Engine, Exhaust, Transmission 23 11-23-2021 10:39 PM
Ticking/Rattling noise at idle. Razgriz Issues | Warranty | Recalls / TSB 4 08-17-2017 10:02 PM
Engine rattling at idle Sketchi Issues | Warranty | Recalls / TSB 6 03-24-2015 01:15 PM
New rattling sound at idle IAmNotTheDriftKing Issues | Warranty | Recalls / TSB 20 10-24-2014 03:33 PM
Transmission rattling Sonolin Scion FR-S / Toyota 86 GT86 General Forum 6 04-29-2013 02:57 PM
