Old 03-22-2015, 10:42 PM   #1
Sketchi
Drives: frs
Engine rattling at idle
So I've been boosted for about 2000 miles, everything is going great but I notice after 3 or 4 hard pulls over 6000 rpm when the car is idle it sounds like some serious engine rattling going on. Obviously the engine is hot but is this something I should worry about?
Sketchi is offline   Reply With Quote
Old 03-23-2015, 12:18 AM   #2
pantdino
Drives: Firestorm 2013 FR-S
I'd take it to a mechanic to see what he thinks.
1995 BMW M3, 1973 DeTomaso Pantera, 1972 Dino 246GT, 1964 Fiat-Abarth 1000TC vintage racer
pantdino is offline   Reply With Quote
Old 03-23-2015, 12:32 AM   #3
Koa
engine oil temps shouldn't matter whether or not you have a rattle at idle...
Can you focus where exactly the rattling is coming from?
Old 03-23-2015, 06:02 AM   #4
Sketchi
Drives: frs
Maybe rattle isent a good term to use but it basically sounds like metal grinding and the engine is about to jump out of the car. Oil pressure goes down but after a few seaconds it comes back up and sound stops. I'm getting most of my fluids changed and an oil cooler installed today so I'll ask them. I just assumed it was the engine trying to cool off or something
Old 03-23-2015, 08:37 PM   #5
BRZnut
Drives: BRZ DGM Limited
Can you post a video of this??
Old 03-23-2015, 08:54 PM   #6
Spicer66
Spicer66's Avatar
Drives: Raven 6 MT
Clutch pedal in or out make a difference at all?
Spicer66 is offline   Reply With Quote
Old 03-24-2015, 12:15 PM   #7
Sketchi
Drives: frs
Well they said the oil was getting too hot, and I'm inclined to believe it because the oil cooler solved the problem. So for now all is well. I'll just have to see if this happens during a track day. Hopefully because I put the cooler in front of my intercooler it won't heat soak.
The Following User Says Thank You to Sketchi For This Useful Post:
Tcoat (03-24-2015)
Unknown Engine Rattling (Video) Kronos Issues | Warranty | Recalls / TSB 72 01-28-2018 10:51 AM
New rattling sound at idle IAmNotTheDriftKing Issues | Warranty | Recalls / TSB 20 10-24-2014 02:33 PM
Engine rattling/vibration happening between 3k - 3.3k Boofneenee Issues | Warranty | Recalls / TSB 4 05-18-2014 02:34 PM
Rattling from front of car when you shut the engine off djdrugga24 Issues | Warranty | Recalls / TSB 8 04-01-2014 12:03 AM
Rattling noise under the hood during engine braking at low RPM Sigh-on-Rice Engine, Exhaust, Transmission 60 07-28-2013 07:48 AM
